Question about Jenn-Air JGR8850 Gas Kitchen Range
Model #3627555190, everythings works, but the bake, how to fix?
Need manual for Kenmore oven model#C970-648141
I am looking for a manual to a Kenmore Self-cleaning Convection Oven. I bought it used it has selection for conv bake, conv roast, bake or broil. According to the website, my model number doesn't exist -- really? Everything works perfectly - I just want to understand the difference between "bake" - "Conv bake" and "Conv Roast"
Mar 29, 2013 | Kenmore Kitchen Ranges
I AM TRYING TO FIX A EB378610 SINGLE OVEN THAT HAS NO POWER WHEN YOU TRY TO BAKE. IT HAS 220V INTO IT. LIGHTS AND EVERYTHING ELSE WORKS. CANYOU HELP
if you test Bake (Yellow Wire) to L2 (Red Wire if your oven has it) and you read 240 volts while the oven is on and baking you need a new element. If you take the bake wire off and test the tab coming off the board to ground if you read 0v while the bake is on then you need a new control board
Dec 18, 2008 | Ovens
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Baking element
Hey there. make sure the clock in on manual and not automatic is should show a little hand and not a 0 :)
Sep 05, 2008 | Kitchen Ranges
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Control unit is probably the problem, You should check your Breaker to make sure it didnt trip outside of that you can check voltage to the element with the oven set to bake, if you dont have votage to element then it would most likely be the board. I just checked the wiring diagram for this unit and there is an over limit switch which is a long shot but worth checking. My bet is on the board. There are 2 listings for the part number so if you check on parts make sure you have full model # serial # AND series #(should be a 2 digit number like 10 or something)
Mar 20, 2008 | Maytag MER5775Q Electric Kitchen Range
Jenn-Air JGR8850 Gas Kitchen Range Logo
26 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
