Philips GC 8220 Iron Logo
j
john kane Posted on Nov 23, 2013
Open case to change main cable - Philips GC 8220 Iron
My panasonic NI22AWTXJ iron is not powering
Get a multimeter. Check that the fuse is OK. If it is ok, open the cover at the back of the iron. Plug in the iron. Be careful not to get electrocuted. Check that the cables from the socket on the wall have power. place the leads of the multimeter on the live and neutral and check for 240V or 110v depending on your country. If no power here cable could have a problem.
If there is power here, turn of power and unplug socket. open top cover, you will see the heating element. Check for continuity between the ends of the element, If no continuity the element is dead and you need to buy a new iron. If it has continuity then check continuity of other components connected in series with the element. Some models a limit thermostat to prevent the iron from over heating. This looks like a small resistor about one centimeter long, if it has no continuity, cut it off and bypass it. It is a safety device that fails when it senses high temperatures in case the main control thermostat fails. If you can find a replacement replace it, if you cant find a replacement, you can use it and hope the main thermostat does not fail.
2answers
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 • Tefal Irons
Black & Decker iron D6 100C stopped working with no apparent reason.
please provide more details. You should check the fuse and the cable. try it in another power outlet
May 27, 2015 • Irons
How do I find out why my singer magic press 4 won't work? no light comes on, no heat
Assuming you have tried different power points in the house, it is likely the mains cable plug of the iron is faulty. Worst the cutoff fuse or control inside has tripped. Would suggest if mains cable or plug is ok then buy a new iron as these can be risky to repair without knowing what one is doing.
Aug 26, 2014 • Irons
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
2answers
My iron will not turn on....what's wrong?
Welcome to Fixya. If the iron wont turn on it can be caused by a faulty cable, a busted Fuse, transistor, capacitor, switch problem or the main board of system. If you have warranty then you can have it checked an repair for free or if you have knowledge with electronics then you can open the iron and check hte part that is bad
Thanks
Damaged mains cable
it is betterr to get a sealed power plug with the nylon insulation for the iron with a 15 amps rating wire and plug.
open the unit and disconnect the wire of the damaged plug, remove and replace with the new one taking care to connect each of the wires to the correct position. The lead , neutral and the ground must be double checked before you switch on.
1helpful
Rowenta dm860 stop heating and nno power
If the input led is not glowing it means the connection to the mains inside your iron has got disconnected. Just open the iron. Check the input on the mains and check all the three wires are connected properly. It will heat again. You might have been changing to other type of clothes which requires more heat. Hence, you asked more voltage to the heating element and possibly due to more voltage the connection got broke and now the circuit is incomplete hence no led and no heatup.
5helpful
3answers
My iron stooped working all of sudden.I was pressing cotton clothes, all of sudden it stopped heating. No light in it.
If the input led is not glowing it means the connection to the mains inside your iron has got disconnected. Just open the iron. Check the input on the mains and check all the three wires are connected properly. It will heat again. When you were changing to cotton. You asked more voltage to the heating element and possibly due to more voltage the connection got broke and now the circuit is incomplete hence no led and no heatup.
Apr 25, 2010 • Irons
3answers
My iron won't work
you have to check the cable you can use multi tester in ohm position to make sure the connection no problem, and turn the adjustment temperature and watch on multitester the resistance will change if nothing happen you have to change cord with new one.
Top Philips Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Philips Iron Expert? Answer questions, earn points and help others
