Question about Toys
Hot focus safe pin reset - Toys
2 Suggested Answers
emissionwiz
  • 75797 Answers
SOURCE: I need help resetting the password word to my daughters pick hot focus digital safe
You can't reset it or what use would it be to have one. Call a locksmith.
Posted on Oct 24, 2016
Oct 24, 2016 | Computers & Internet
I have lost my key and forgot my pin of my fragram safe how can I reset my pin
If a pin could be reset by going online what good would the safe be??
Sep 23, 2016 | Computers & Internet
How do you reset the Pin on the Hot Focus Pink Digital Safe
Hot Focus Pink Digital Safe pin reset instructions:
1) Hold down the star button (do not let it up until the process is completed). 2) Press a four number code sequence. 3) Press the pound key. 4) Release the star key.
Nov 25, 2012 | Toys
Why does the new pin code request comes after the PUK code request?
This resets the pin code on the SIM card. I suggest you take a note of the pin code and keep it in a safe place. If you forget the SIM pin code then you need the PUK code again to unlock the SIM card.
Also keep the PUK code in a safe place with the SIM card pin code.
Feb 07, 2011 | Cell Phones
I have accidentally locked the sterio of my Ford Focus 2001 Car while inserting a pin code. How do I unlock the sterio so that I can insert the correct pin code
disconnect + battery cable for 5 minutes and re-connect. that should reset the system completly so you can start all over again
Jan 13, 2011 | 2001 Ford Focus
Are there any digital cameras on the market that will allow me to make use of my existing ricoh k mount 35 mm camera lenses? (originally used on a Ricoh KR10
Some pentax digitals(most) will accept k mount lenses. Ricoh differed from the Pentax standard in one slight -- but important -- way. They used a locking pin (called the "Ricoh pin") that just happens to fall at exactly the same place as the auto-focus socket on Pentax auto-focus cameras. (That include Pentax film and digital SLRs with auto focus.) If you put your Ricoh lens on the AF Pentax, you may find that the Ricoh pin will get stuck in the AF hole and you can't get them back apart. The fix is simple, if you are even a little bit handy and have a jewellers' screwdriver. You can remove the pin from the Ricoh lens, and then safely use it on your Pentax cameras. The lack of a pin doesn't seem to adversely affect either the lens or the camera.
For more details, see here:
http://forums.dpreview.com/forums/read.asp?forum=1036&message=19214685
Nov 04, 2010 | Photography
My ford focus 2001 didnt pass the smog test, they said to reset everything my question is how can i reset the computer of my ford focus 2001. thank you in advance
a good way to grantee to pass the smog test is a bit brutal but it works .find somewhere you can drive safely and drive your care as fast as you can in first and second gear .to the rev limiter and this will clean the carbon off the engine.this really works and don't cast a penny.steve
May 21, 2010 | 2001 Ford Focus
Hi have a ford focus 1.8 zetec 1999 trying to replace the speed sensor i have removed the retaing pin eventually however im having difficulty removing the sensor still its stuck tight are there anymore...
pulls out but are very tight try warming the area round sensor very carefully with a hot air gun then try and twist it i have had them where i have had to drill hole in sensor screw in slide hammer to remove
Feb 08, 2010 | 2000 Ford Focus
Diagram for timming belt on 2002 ford focus 2.0ltr
there isnt marks!the cam pulleys have do nothing with timing!remove the valve cover and see in the other end of the camshafts and find two eccentric cuts!turn the crankshaft to the top dead point on the cylinder 1 the two cuts must be in the same line on the upper or lower side.you need aspecial tool to lock the camshafts and another to lock the crankshaft!this is the timing procedure!now you can change anything you want!note!the cam pulleys are conejointed to the camshafts!no marks no pins no safe pins etc.isnt difficult but complicated simple!
Jan 23, 2010 | 2002 Ford SVT Focus
Blue Hat Bank
Type in the code 1234 ENTER then enter your child's new pin.
Pax, Moncia
Jan 04, 2009 | Blue Microphones Blue Hat Little Shots...
Toys Logo
65 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
