Logik soundbar remote changes tv function settings when used
When i use the remote to alter the sound on the logik soundbar it changes my tv setting from HDMI 1 (TV setting) to another input ie hdmi 2/3/4 can i program my virgin remote to operate the soundbar ?? Thank any help would be appreciated
SOURCE: Using a Jensen remote, can't access input mode
turn on your tv, press and hold tv button, then the on/off button, it will light up then press the power button.and it turns off....hold. After holding down both for buttons for 3 secs the light on the on/off key turns back on. Release both keys and the light should stay on. Now hit the On/off button repeatedly until the tv turns off, when it does hit the stop button to save code.
Posted on May 05, 2007
thecritter
  • 29 Answers
SOURCE: I cannot get a signal on my Phillips 50
if you haven't unplugged the unit for 30 seconds, try that. otherwise, if that doesn't help, probably a board needs to be replaced. call phillips for service.
Posted on Mar 17, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
I have just connected SC-HTB498 sound bar using HDMI to my Samsung TV but I am getting no output. Any Ideas?
Power off the television and unhook the power connection. Wait a minute reconnect it. Try again.
Mar 11, 2018 | Samsung Audio Players & Recorders
No sound from tv. it says 'paired - not connected' How do I connect? Thanks
You have a soundbar?
And the soundbar is paired?
Next... go to your TV remote control ... navigate into settings... and change the sound setting to external device
Mar 02, 2016 | iHip Audio Players & Recorders
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
How do i connect my soundbar to my technika lcd 32-244 tv
There should be a output on the TV. Hook the sound bar up, set the TV up to use external sound and use the sound bar remote untill you sync it to a different remote. Give it a try!!!!
May 22, 2014 | Televison & Video
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
PhillipssoundBar htl2101A
You have to use the TV remote to set the TV sound option to external. Look on TV setup menu for 'external output' or 'external speakers'.
Dec 15, 2013 | Philips HTL2101/F7 Soundbar Speaker Spkr -...
No sound
Start by checking wiring connections. Also check the mute function on your tv/remote. You did not specify which console you are using but you may have reset or altered the settings on the console itself and turned offthe sound. Check your console settings with your console remote and console main menu.
Mar 02, 2011 | Video Game Consoles & Games
Has anyone got a code for my Logik L40DIGB20 tv to use with my sky remote control please. I have contacted sky, the techguys, currys, and even checked out the Logik website all to no avail. I am hacked off...
MY TV SWITCHES IT SELF OFF AND THIS PROBLEM ONCE BEFORE AS IT IS AN EX DISPLAY TV AND IT WAS ON A TIMER. SO I ALTERED THE SETTINGS TO OFF BUT FOR SOME REASON ITS GONE OFF AGAIN AND I CANT GET IT BACK ON.
Dec 27, 2010 | Televison & Video
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
