Question about Blitzz Technology BWI715 Super G 802.11g/b (b000220dgm) Wireless Adapter
Pci bwi 715 not working
Lynk sys router died, added new Belkin router, all four computers work except one with Blitzz card in it, belkin said they dont know how to locate card utility to make it work?????
  • jaytb123 Mar 04, 2008
    I put router with cable modem on main computer. (used Motorola install disk) Got internet working there but not on this pc. This pc has super g wireless card, but no disk for it., therefore, no internet
  • 661 Answers
All you should need to do is to Discover available wireless networks on the machine with the Blitzz card in (it should be able to discover the belkin Wireless router)
you should have a wireless utility program that came with the card that lets you alter the configuration so that you can connect to this different router.
Posted on Oct 15, 2007
  • Gareth Cockram
    Gareth Cockram Oct 15, 2007
    I just think that Belkin is not familiar with the Blitzz wireless utility (and nor should they be)
SOURCE:
My computer crashed and i restored it. I cannot access the internet. I have a Belkin 802.11g wireless PCI Adapter and the software for the adapter is on my computer but I can't adjust any of the settings...
Please go to command promplt and type ipconfig. You should be getting an ip address as 192.168.1.x and Default Gateway 192.168.1.1 .
Try to ping 192.168.1.1 from your command prompt
If you are getting responce means you are connected to the Belkin wireless Router.
If not then try power cycling the Belkin router once.
If that also not working then you may have to go for a driver update.
Oct 30, 2010 | Belkin - F5D7000 - 54Mbps 802.11g Wireless...
Belkin router Flashing 5 out of 7 lights constantly. Help?
can you replace any cables to and from this router? Also, is it possible to turn it off for 5 minutes and retry?
Jul 06, 2009 | Belkin (F5D5231-4) Router
Laptop won't connect to new Belkin G Wireless Router
Just Install the hardware and insert the driver of the router...then follow the instruction...
May 10, 2009 | Belkin (F5D72304F5D7000) Router
Belkin Wireless connection speed at 11mpbs. Why not 54mpbs?
this is from the d-link support page:
"Question :Why can't I get the advertised speed and performance when in Ad-Hoc mode?
Answer :
This FAQ applies to 802.11b, 802.11g, and Super G™products.
D-Link wireless products follow the IEEE 802.11 standards. The802.11b and 802.11g standards specify that Ad-Hoc mode only needsto support up to 11Mbps. For best results, use an access point orwireless router and set your adapters to Infrastructure (station)mode."
Feb 03, 2009 | Belkin (F5D7000) 802.11g/b Wireless...
Router problems
I've seen many routers die this way. Belkin routers have a tendency to go intermitant before they die. If your computer can get onto the net when connected to just your modem, then the router is the answer.
Good Luck
Sep 28, 2008 | HP PAVILION A6230N DESKTOP PC
Super g wireless install
I HAVE SAME PROBLEM LIKE TRUCKER 77546 .I NEED A DRIVE OR SOME THING TO INSTALL BWI 715 SUPER G802.11g/b ON MY NEW COMPUTER .BECAUSE I HAVE LOST MY SOFTWARE DISK FOR IT! THANK YOU.
Feb 11, 2008 | Blitzz Technology BWI715 Super G 802.11g/b...
BWI 715 Super G wireless driver for Windows
I have the original CD Drivers, If you want I can share it with you.
Jimmy.
Jun 19, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
BWI 715 Super G Wireless driver
It turns out the BWI 715 is the same as the D-Link 520 Rev B. http://support.dlink.com/products/view.asp?productid=DWL%2DG520%5FrevB# Select that as the driver and it'll work.. D-link even has Vista support so you might be able to get it to work in Vista. They share the same FCC ID KA22003070025-1 Which means they are identical in every way.
Unstable connection
This maybe because both peices of hardware are not set at the lower speed of 54mbps as super g is set at 125mbps and can cause problems with streaming. The speed has to be set the same for both, both beind 54mbps. See if this cures it.
Dec 24, 2006 | Blitzz Technology BWI715 Super G 802.11g/b...
Blitzz Technology BWI715 Super G 802.11g/b (b000220dgm) Wireless Adapter Logo
184 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Hollyecho Montgomery
didi2005
GFXTech
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
