Question about Canon Office Equipment & Supplies
E806-0000 Get this code on imageclass 8380. Powers on, starts the power on process of checking motors, hear the scanner move, then a few clicks, everything stops and I get the code: E806-0000 on the LCD, saying to power on the main power, if it continues call service.
  • 138 Answers
You are having a fan error. The fan is not operating properly. Here is a copy of the error section from the manual.
Posted on Jan 15, 2014
  • bryan parrish
    bryan parrish Jan 15, 2014
    Hi. Thank you so much. I did not see any attachment in you solution however. This is an image I found during my research (see attached). Is this the same diagram that you have ? This shows E806-0000 code is refering to: (FM6 Main body cooling fan Cools the power supply. E806-0000 ). If so, I wasn't yet able to find that part online, perhaps I have to call Canon?
  • parkerguy Jan 15, 2014
    The part can be ordered from www.precisionroller.com. They don't stock it but can get it for you in a couple days.
TV powers on with no splash screen and then powers off.
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 14, 2014 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Kenmore electric blue,, powers on and sets to types.. but when start button is pushed you hear a click and and code f 40....... flashes
Run start winding in motor need the black box connector forget the name of it..or you can purchase new motor
Oct 21, 2013 | Kenmore Dryers
What component makes the loud click when you power on certain electronic devices?
the click is the relay which clicks when the set is powered on or off. Your model should store an error code when it shutsdown or wont start up. Have you tried accessing the self diagnosis feature to retreve the error code through the power indicators two digit blink sequence? If so whats the blink code your receiving?
Apr 05, 2013 | Mitsubishi WT-46809 46" Rear Projection...
Hi, Just replaced two batteries. Chair powers on but I just hear a click sound when I push the button to move chair. please help. thanks.
The fact that you just replaced the batteries indicates a battery problem that has been solved. Please make sure the new batteries are fully charged. The fact that the power wheelchair powers on is an indicator that the VSI controller (joystick) is working. When you move the joystick forward you will hear a click sound from the motors and electromagnetic brakes. The click is the brake being released by the electromagnetic solenoid. If you have a flash code on the controller and the chair does not move you can look up the flash code using the following link:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
This motor/brake problem is typical for the Aspire and can usually be traced to the large connector at the back of the power chair. Pull out to disconnect the 8 pin connector and disconnect the 3 pin molex plug. Inspect and clean with electronic contact cleaner the silver pins until they are shiny. Spray clean the plugs. Work the plug in and out to clean the inner contacts. If the chair now runs you have traced the problem to the main harness receptacle and the VSI controller plug. The only cost effective repair of the the main harness receptacle is to replace it. The VSI plug is can be cleaned several times before it needs to replaced or the controller rebuilt.
If you need to replace a motor/brake assembly you need to contact a qualified technician who can troubleshoot further with a PP1 programmer to read the fault code history log. The technician will also have a digital voltmeter to verify your motor/brake problem. In my experience, the motor/brakes can last up to 3 years depending on use. The wiring harnesses at the rear location are easily hit and are usually more problematic because of their location, collecting dirt, moisture, and corrosion. Hope this helps,
Nov 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
JVC Model #: AV-56p575--------problem with power
If this clicking is a continuous clicking sound its likely that its coming from the ballast.The ballast is the component that powers the lamp.If this component fails your lamp wont ignite and wont allow the start up to continue.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
ERROR CODE C0660
This is a scanner problem, try the following...
C0650, C0660
Step Check Item Result Action
1 Scanner can be moved manually.
NO Correct drive coupling (Scanner
Belt tension, pulley operation,
drive cable tension)
2 Scan motion: initial scan motion after the
Power Switch has been turned ON or Front
Door has been opened and closed.
NO Carry out misfeed/malfunction
troubleshooting procedures.
3 Connectors are connected properly on
Scanner Motor Drive Board: PWB-IC
PJ1IC, PJ2IC, and PJ3IC.
NO Check connectors for connection.
4 Scanner Motor turns when the Start key is
pressed.
Change motor. Change
Scanner Motor Drive Board.
5 I/O check for Scanner Home Sensor: the
voltage across PJ6C-2 on Image Processing
Board and GND is DC 0 V (home position)
when the sensor is blocked and DC 5
V when the sensor is unblocked.
YES Change Image Processing
Board.
NO Check sensor for installation.
Correct detecting plate.
Check sensor connector for
connection. Change sensor.
6 “IR Area” check:
Malfunction when Power Switch is turned
ON after “Top Image” has been set to 0 and
“FD-Mag.” to 1.000.
Apr 03, 2008 | Minolta CF2001 Copier
Scanner
If the motor (light) does not move after a scan command, it could be a hardware problem. Try uninstalling and reinstalling of the scanner driver.
Mar 08, 2008 | Office Equipment & Supplies
1,135 people viewed this question
old marine
old marine
