Question about Fisher and Paykel DEGX1 Electric Dryer
Bush tdv6w dryer flashing lights and wont start
When i switch on my tumble dyer i get flashing lights and it wont start
2 Suggested Answers
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Posted on Jul 16, 2010
I have a tumble dryer bush tdv6b got from a friend not very old was working fine now its not doing anything apart from a slight buzzing noise tried the reset at the back does nothing thanks
MOST PROBABLY THE CAPACITOR BESIDE THE MOTOR NEEDS REPLACED. http://www.buyspares.co.uk/tumble-dryer/tdv6w/capacitor/product.pl?pid=4058219&shop=bush&path=864668&refine=capacitor&model_ref=8702213
Jan 31, 2016 | Dryers
I have a bush tumble dryer TDV6W and each time its switched on it trips the electric whats the cause?
guessing the heating element has shorted to ground . call for service.
Jan 17, 2015 | Dryers
I have a bush tumble dryer TDV6W but when I put it onto the extra heat part the botton flashes and cuts my electric out, whats wrong with it, its only 4 months old
Hi Margaret, 4 months old? warrenty problem! it may also be a shorting temperature sensor. How old is the wiring in your abode? Possibly circuit breaker faulty.
Dec 30, 2014 | Dryers
My bush tdv6w vented tumble dryer is not heating up
If your dryer is an electric dryer, it is sounding like you have either a bad heating element or one of the two limit switches are open. The limit switch is an "overtemp" device to shut down the element if it gets too hot from air restriction. Lint build up in the blower and ducting is a major cause of restricted airflow across the heating element. Excessive tripping of the limit will result in an "open" limit switch and continual failure to generate heat. There should be one limit switch built into the heating package and the high limit will be located on the drum usually near the top, though there are some near the bottom of the drum as well. Any attempt to find and replace must be done with the power off as you are dealing with 240 volts.
If your dryer is gas fired, you've had a misfire probably due to a defective hot surface igniter or bad control module. Unless you are fairly capable of learning as you go, and have the basic tools for troubleshooting you probably need to call a sevice technician.
Dec 13, 2014 | Dryers
Bush tdv6w tumble dryer wont start just flashes lights and beeps
All these sound like good advice but in addition - there is a re-set button on the back of this machine, push it and see if the problem continues. If you still have the same problem after re- setting your machine please call their customer service line at 0345 640 2020.
Nov 25, 2013 | Dryers
My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip.
Jun 30, 2009 | Maytag SDE2606 Electric Dryer
Dryer won't start
Check the door switch, if the switch is bad the dyer thinks the door is open it will not start.
Apr 22, 2008 | Whirlpool GEW9250 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
283 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
