Question about Dishwashers
The washer fills with water and then stops
Wqp12-9011e
  • 3,961 Answers
It is possible that the start capacitor has failed. You may need a service call.
Posted on Nov 23, 2013
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Water level
Probable causes:
Faulty water inlet valve - unplug washer, if water continues to fill
replace the valve.
Water level switch, hose or dome faulty - service the assembly.
Timer faulty - unplug washer, if water stops filling test timer.
Regards,
Dennis
Aug 22, 2014 | Simpson Esprit 750 Top Load 7.5kg
Won't stop filling with water, seems to fill to top and keep filling
there is a water connector that the water lines from the house connect to the washer. you will need to take the panel off. you should see a blue plastic box where the hoses connect. you will need to replace this piece. it should have wires on it and that tells the washer when to open the valve for water to come through and when to stop.
Jan 27, 2011 | Frigidaire FWS833A Top Load Washer
Washer won't stop filling
Does the water stop filling if machine is unplugged? If yes, bad water valve inside washer.
If water stops when unplugged, may be a faulty pressure switch or airdome hose came loose from switch - located in control panel - water level switch.
If water keeps filling and never overflows onto floor - likely that water is siphoning out drain hose. Raise drain hose higher or allow an air break at the drain hose exit.
Jan 21, 2011 | KitchenAid KAWS750L Top Load Washer
Water fill doesn't stop filling cold water
check washer pressure vale and the tube connect from the tub to pressure vale most of the time the mouse bite the hose some where in the panel con trol of the washer good luck
Mar 03, 2010 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
