Question about Agfa SnapScan Touch Flatbed Scanner
Twain driver - Agfa SnapScan Touch Flatbed Scanner
Twain driver for hp scanjet G2710
I just wonder how to choose the right twain scanning API for the scanner. By the way, you can ask your question at HP support forum, also, like
http://h30499.www3.hp.com/t5/Scanners-Experts-Online-Now/64-bit-Twain-driver-for-HP-ScanJet-G2710/td-p/2337525#.U3k8IHYoZ2M
VB NET TWAIN TWAIN Scanning Using VB NET
Jan 18, 2012 | HP Scanjet G2710 Flatbed Scanner
Need Twain driver for windows 7 for canon Scan N12400 flatbeb
The TWAIN drive should be installed when one installs the actual "Drivers" for the unit itself, accordingly I provide you with the download link below.... look for and install ALL drivers and software, especially the Scan manager and TWAIN drivers....
http://usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u
Sep 28, 2011 | Canon CanoScan N1240U Flatbed Scanner
Where can I find TWAIN driver for a Canon CanoScan N670U for Win-XP
You can find the winows XP drivers here for your scanner:
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n670u?selectedName=DriversAndSoftware
Choose Operating System: Windows XP and you will see a list of the drivers.
the second one is the Twain Driver. I recommend installing both the regular driver and the twain driver both are available from the above link.
lide20lide30n670un676un1240uvst7031a_xpen.exe TWAIN Driver - N670U Scanner Driver Ver. 7.0.3.1a_xp (Windows Vista32/XP/2000)
Mar 02, 2011 | Canon CanoScan N670U Flatbed Scanner
I need a twain driver
I can understand that u get TWAIN driver not installed or required error on PC while scanning.
Twain drivers are imaging driver which are bundled with complete software.
Incase if you try to replace just the twain driver it may corrupt anoth files.
It is always advisable to clean the computer and reinstall the complete software.
Jul 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cannot communicate with twain devise
I suggest using ISIS drivers instead of TWAIN. I have always had trouble with the twain drivers failing especially in paperport ive found the ISIS drivers to be much more stable.
If you do require TWAIN though best way to fix is un-install the software that the TWAIN driver came with and re-install it. Unfortunately thats the easiest solution.
If you want to try the isis drivers they should be on the cd that you used for the twain drivers just select isis instead.
Let me know if you need further assistance.
Mar 22, 2009 | Brother MFC620CN Home/Office Color Inkjet...
I have a Canon scanner 5000f. All of a sudden the computer won't recognize it and says it is "unable to select Twain Source." What do I do?
First you need to follow the instructions for installing the scanner. It is important whether you connect the scanner before the software is installed and whether you work from the new hardware found box or just install the driver as software. It sometimes varies between operating systems as well.
Sometimes the twain files can become corrupted. Since other devices like digital cameras use the twain files they aren’t erased with a driver uninstall or overwritten with an install. If the twain files are gone the driver install will also install them.
Uninstall ScanGear (I think that is the Canon driver software) and remove the scanner if it is still showing in device manager and control panel under scanners. Unplug the USB.
Do a search for twain and delete all you find in the Windows folder. There is probably a folder and several files – delete them all. Do not remove any twain files not in the Windows folder.
Dig out the instructions and reinstall the scanner exactly according to them.
Jan 14, 2009 | Office Equipment & Supplies
Twain drivers
The problem was with the scanner,it was not twain compliant
So the 2 ways left with me was :
1.Download twain drivers for my scanner and install it.
2.Use wia32.dll
I chose second option as i didnt found any twain driver for my scanner.
Hope this can help any one.
Aug 30, 2008 | Office Equipment & Supplies
Twain driver for scansnap s300
The scanner can not be used with Twain.
3 TWAIN or ISIS® applications cannot be used directly.http://www.fujitsu.com/us/services/computing/peripherals/scanners/scansnap/s300.html
Apr 12, 2008 | Office Equipment & Supplies
Downloading software (Twain??)
The download website for your scanner is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8008
A TWAIN driver is simply a generic scanner software driver that your specific Canon software can hook into and use.
I recommend starting with this one and see if it installs the TWAIN driver you need:
"CanoScan Toolbox v2.2.3 for Windows 98/Me/2000/XP"
Nov 18, 2007 | Canon CanoScan N656U Flatbed Scanner
Is it possible to install only the TWAIN driver for my PDC 640 camera?
Yes, you may install the PDC 640 camera TWAIN driver only. The PDC 640 TWAIN driver can be used with most TWAIN compliant image editing software. The most current driver is available for download on our website and is compatible with Windows 95, 98, Me, 2000 and XP (there is no compatibility with Windows NT at this time).
Sep 14, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Agfa SnapScan Touch Flatbed Scanner Logo
Top Agfa Office Equipment & Supplies Experts
Chris Larocque
Pierre Legault
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
