Question about Canon PIXMA MP610 InkJet Printer
Canon mp610 cannot reactivate black ink
I disactivated the PGBK Black Ink Cartridge when I had low ink by holding down the red Stop/reset button. Now I have replaced the cartridge, I can't find how to reactivate. The ink doesn't appear AT ALL on the nozzle print check.
    New Friend:
Get colored ink
Posted on Nov 23, 2013
  • 6 Answers
SOURCE: reset Ink levels for canon mx310
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Posted on Feb 23, 2008
old marine
  • 2131 Answers
SOURCE: Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Posted on Oct 14, 2008
websnail
  • 419 Answers
SOURCE: Not printing black ink after replacing cartridge
Unfortunately I have no idea which compatible cartridge you're using so it's difficult to provide a definite solution. However a few things to consider:
1. The cartridge needs to have a clear vent hole so if you haven't removed tape or a plug from a hole that was indicated in the instructions, you need to do this.
2. Try removing the cartridge and then touching the exit port on the cartridge with a Q-tip (cotton bud) to see if the ink flows to the cotton. If it doesn't you need to replace the cartridge.
3. Check the cartridge is sitting properly in the printhead.. The interface between the printhead, rubber grommet and the cartridge exit port is very important and the cartridge needs to sit in this properly.
My guess is that the compatible cartridge is not up to the job and you need to consider getting an OEM (Canon original) instead.
You may want to think about finding a refill kit and using the Durschtich (German) method of refilling using bulk ink and a chip resetter instead of compatibles.... Nifty-stuff forums have a LOT of information on this subject so it's well worth a look.
Hope that helps.
Martin
Posted on May 28, 2009
don_farr
  • 1018 Answers
SOURCE: Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
Posted on May 30, 2009
  • 164 Answers
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
How do I reset the black ink low in the Canon pixma MX472
Try holding down the stop/reset button on the printer for 5 seconds. It should clear the empty ink cartridge message.
Feb 22, 2015 | Canon PIXMA MX472 WIRELESS OFFICE...
I have a Canon Printer PIXMA MX870. My black ink (PGBK) has run out. Will the single black (BK) kick in? I've looked for the user manual which might describe this but couldn't find it.
The black ink (smaller cartridge) will not kick in, but if you are just getting the warning that the ink in the larger cartridge is out, you can override the alam by holding down the OK button on the printer. Once you do this, the printer will continue to print, but you have to manually monitor the ink to assess when the cartridge needs to be replaced.
Let me know if you have any other questions. Thanks.
Apr 26, 2011 | Canon PIXMA MX870 Wireless Office...
Hello,i want to ask-how reset canon mp 490 ink cartriges level,or how reset the printer?sorry for my english
I tried pressing the OK button for 6 seconds, while holding it press the red stop button and hold it until the LCD refreshes.
Nov 04, 2009 | Canon Office Equipment & Supplies
Printhead is blocked but it's only the Black PGBK cartridge on my Canon MP610 printer. All other colours are working fine. I can't print a letter unless I select a photo paper.
try removing the black cartridge and with a q-tip and some rubbing alcohol clean the cartridge where the ink is. Re-insert and clean the heads.
Oct 30, 2009 | Canon MP610 Photo All-In-One Printer
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Canon MP610 out of black ink
Cannon Pixma MP610 - when the black ink is empty and you receive the replace ink message, then hold down the "cancel" button for 5 seconds or so and it the printer automatically bypasses the problem. It does work but Ive had mixed success in terms of the print quality when doing this.
Mar 26, 2009 | Canon MP610 Photo All-In-One Printer
Trying to reset chip on refilled ink tank on CANON MP830
Looks like Fillserv.com has a chip resetter for the CLI8 color cartridges, but I don't know if that unit will reset the big black PGBK cartridge in the MP830.
Nov 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Black ink
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MP610 - cartridge replacment problem and B & W printing.
resit your ink cartridge and check for other cartridge are empty
when printing you go to properites in printer dialog box from there you can select the option
May 29, 2008 | Canon MP610 Photo All-In-One Printer
Canon PIXMA MP610 InkJet Printer Logo
126 people viewed this question
old marine
old marine
