Question about Hoover HTC243 Top Load Washer
Hoover 200m 4.5kg Top Loader - Can't Remove Agitator
I was trying to remove the agitator and removed the bolt holding it down but the agitator will still not lift off. I asked a repair guy he said he wouldn't be able to get it off but he didn't really try. He yanked it a few times and then left. Is there something i'm missing?
SOURCE: Hoover Premier 706
I have the same washer and the paint started to flake from the bottom of the bowl. Rust under the baked enamel made it lift. I peeled the loose paint then applied rust converter and a zinc paint. This patch is still ok after 12 months but my wife is complaining about paint flakes and rust on some clothes. In my opinion, the only way to remove the agitator is to undo the nuts retaining the shaft from the inside. I guess I will find patches of rust under the agitator and depending on how big and deep they are will determine if I replace the machine or patch the rust.
Bob
Posted on Jan 28, 2008
SOURCE: need to remove agitator on
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
Posted on Mar 12, 2008
abhishek33
  • 1239 Answers
SOURCE: how to remove agitator
hi The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Posted on Nov 11, 2008
  • 220 Answers
SOURCE: A button has gone under the agitator. will this harm the pump
Most top loader machines have some sort of fastener in the center at the top of the agitator. You should look right at it when you open the lid. Once you figure out how you remove the fastener, the agitator should pull straight up. It is usually connected by a spline. You may have to pull pretty hard if it has never been apart. Once the agitator pulls out, you should be able to see the debris you are looking for.
I am not familiar with your exact machine, but yours should be similar. Hope this helps.
Posted on Jan 16, 2009
e-Guru
  • 3917 Answers
SOURCE: How can I remove the agitator on a premier 510 model
Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some washers may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Thank you for contacting Fixya.com
Posted on Aug 05, 2009
After removing the bolt that holds the agitator it won't lift out. what should i do?
Spray a little penetrating fluid into the area where the bolt holds the agitator down, leave for a while and spray again. This should release the build up of corrosion that is making it difficult for you to extract the agitator.
If this does not work try sliding two wooden wedges in under the agitator to force it up.
Aug 27, 2014 | LG Washing Machines
How to repair the doggettes
Pop off the cap on top of the agitator. After you've done that, you'll see a bolt head down inside the agitator. Grab a socket wrench and the appropriate size socket and remove the bolt. Then, lift up on the agitator and it should come out. Then, remove that piece that the head of the bolt you removed was holding down. That's where the doggits live. You should be able to figure it out from there.
Aug 27, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
How to take washer spinner off
Remove the top of the agitator, remove the bolt that holds the agitator down and lift the agitator off.
Nov 23, 2012 | GE WBSR3140DW Top Load Washer
Water is draining very slowly out of the washer and if it takes to long it gives a code of DR
Hi
It seems that something is stuck and you'll have to remove the agitator to clean it. I f this is an old style washer, then it should have a bolt under the cap that must be removed to remove the agitator, then grab hold of the agitator and lift up. If it's a not too old then the agitator just pulls out, remove cap, if no bolt, just grab hold and lift up hard...picture. You can also clean the drain hose as that might be clogged if the agitator is fine. Hope this helps...please post back for further assistance.
Daniel
Jan 10, 2011 | GE Spacemaker WSLP1100D Top Load Washer
The bottom part of the agitator will turn, but not the top part
The agitator has two parts. One is the bottom agitator and then you have the top agitator that moves the clothes around. If the top part of the agitator is not moving. You probably need to replace the dog ears. Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid. -- click on this link directly to get the detailed instruction for replacing dog ear
http://www.american-appliance.com/catalog/newsdesk_info.php?newsdesk_id=136
to remove the whole agitator check out the instructions as follows:
(1) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1, picture2.
(2) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator. also you can get the exact required parts from www.repairclinic.com
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 25, 2009 | Kenmore Washing Machines
My washer has had streaks of grease coming from under the agitator. It is getting on my clothes and I cannot remove it. I took the agitator off and the inside of it is coated with this grease (black,...
GE style washer Common problems: - greeseOil on the clothes or floor. In most cases a new transmission will be required. You can rebuild the Trans for oil on the floor, but I find it best just to replace the transmission with a rebuilt one = less problems and faster repair. I have a parts breakdown of the old style transmission here. How to access the washer information.
Change transmission in GE washer-Take transmission out for repairs. - Unplug washer. Remove agitator from washer by pulling straight up on it, some agitators have a bolt under the cap, remove cap and look for a bolt first. Remove the agitator bearing from transmission hub. Get top up by pressing on 2 clips located about 6 in in from side between top and cabinet. Putty knife or flat blade screwdriver works well here. Take the filter flow tube off. Lift top. Remove three bolts holding basket to hub, and use a 12 POINT 1/2" socket to remove the bolts. Lift basket out of washer. Remove the two clamps holding the black boot to the tub and to the transmission. There are six bolts holding the transmission in the washer. Remove the bolts and lift transmission out of the machine.
To replace bottom seal - Turn trans. upside down in a bucket, put in vice, etc. Remove the nut holding the drive pulley on. Take drive pulley off. You can now pry the oil seal out of the trans. bottom and replace. If you wish to put the proper amount of oil in the trans. you will need to remove the bottom cover. Unless you have lost a great deal of oil, I would bypass this. I would estimate the oil loss and put in a lesser amount through the opening where you will be putting the new seal. When replacing the pulley, do not turn the nut holding pulley on. Hold nut stationary and turn pulley in the direction that nut will tighten. This will keep you from separating the hub, torque spring, and drive collar in the transmission. If you see evidence of water in the transmission, my recommendation would be to purchase a rebuilt transmission and repair in that manner. You may wish to do this regardless of the condition of the trans. You will receive a one year warranty with the rebuilt trans. I have a parts breakdown here for the transmission if you need it.
Usually you have to only add a little oil to replace what was lost...not much...really!!
The oil used is a Non-detergent, Gear oil approximately 90 weight. The main pulley seal is WH8X281 and foam nut seal is part # WH2X671.
Jul 13, 2009 | GE WPRB8050D Top Load Washer
Agitator barely turns, especially with a full load. It's a Roper Washer top loader.
May 04, 2009 | Washing Machines
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
Apr 03, 2009 | Kenmore Washing Machines
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Hoover HTC243 Top Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
