Question about Ricoh Aficio MP 2000 Black and White Copier
Ricoh Aficio 2030 sc571 error - Ricoh Aficio MP 2000 Black and White Copier
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
I want ricoh mpc 2030 printer serial number
The serial will be on the configuration or counter pagel
Mar 23, 2017 | Ricoh 841502 Aficio Mpc2030 Mpc2050...
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
Appel service technique Ricoh aficio 1232C super G3. code SC571. j'ai rempli le réservoir de l'huile de vaseline d'après les forums.mais toujours le...
code 571 low oil top up oil located back of copier reset code press yellow key 1 0 7 press red
key keep held for 4 secounds go in copy sp press 5 press lower cursor key untill you reach 5 810
sc reset code then turn copier off/ on
Nov 08, 2010 | Ricoh Aficio 1232C Color Copier
Two copiers. Gestetner DSM618d - Will not stop showing jam indicator in compartment B. Have a code to call service center error - SC571. No idea. Aficia 200 - keeps saying call service center. Ken...
for the jam code make sure after you have checked that you reset the side door correctly on upper and lower section and that the re is no paper caught behind the paper sensor arm as somtimes if pulled down it can tear and jam the sensor..the 200 might just need the pm counter change or reset..go into the service mode via clear[yellow] 107 then hold down the stop button till the creen changes copier sp and then 7. data log and you can reset the pm there...good luck A
Jun 15, 2009 | Ricoh Aficio 450 Copier
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Ricoh Aficio 1232c copier error code SC571
Enter SP 5-810 and set to 1, then switch off and on the machine.
The 1224C Ricoh Photocopier keeps on displaying SC571 error message.
Try 'clear', '107', 'start' buttons. If that does not work, try different combinations, but '107 should be correct.
Jul 04, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio MP 2000 Black and White Copier Logo
42 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
