Compaq pdp117p schematic
Not working for ac lower then 200v
Schematic
i have same isue humming like hell ,change 2 power supply capasitor didnt do it ,try to changer 2 mosfest transistor Samsung IRF640 N-channel MOSFET TO-220 200V 18A hope it will do it ,on ebay for a 2.00 each .
i think it is power supply isue ,recterfile circuit not clean it will give you that 60hz humming noise ,good luck
will let you know how it turn out ..
Jul 14, 2013 | Mirage OMNI S8 Speaker
Pdp117p not working
The Power Supply is to be replaced if it is bad.
If you see no lights, hear no fan, no hard drive spinning then your power supply might be bad.
May 07, 2012 | Compaq Computers & Internet
Monitor colors are messed up mainly pink
try lowering your RGB settings to the minimum then slowly raise them to a config that works:)
Dec 04, 2011 | Lifetime HP Compaq Presario C700 Series...
What is the center pin used for on the HP 3710b business notebook?I am using a IGO aftermarket power adapter that has the three pin connector tip with center pin like the one DELL uses.Checked with volt...
so what is the full service tag data?
3710b or 6710b, you posted both , and is not complete at all those numbers, (vast submodels exist)
the former number dont fly..
if the PC run ok, on AC pack (HP spec, pack) no battery installed then it (pack) and the PC are ok (no bad jacks)
leaving 2 things, battery (that love to fail) or the charging chip you can not unsolder, ever and replace.
the center pin, seen on the schematic
https://elektrotanya.com/hp_compaq_6510b_6710b_inventec_dd1.0_dosxx_dunkel_1.0_rev_a02_sch.pdf/download.html
or is the AC line loss early warning. (tells PC to go to battery early)
this signal ends up on the charge chip
called Charge Control line.
the schematic is free.
have no battery pack schematic that drives this pin
but its tells the PC to go to (battery early, as power fails AC)
the changer over is not instant
so they this pin tells the PC early, the power is failing
my guess, it can detect power loss, in the pack, in 2 milliseconds flat. (power loss early warning)
Oct 05, 2017 | HP Compaq 6710b Notebook
Compaq nc6000 wiring schematics
there are no schematics availlable However the fan plug wiring when the laptop is facing you is: left to right...red.white,black,yellow
Aug 24, 2009 | HP Compaq nc6000 Notebook
ATS 818 Inoperative
Unplug AC adapter from radio. Remove ALL batteries. Wait 15 min. Reinstall batteries
Jan 17, 2008 | Sangean ATS 818 AM/FM/SW Radio
My compaq 610c EVO will not power up. I applied reverse voltage of 12 volts to it by mistake (wrong power supply) now it will not start up on a good supply. Battery system appears to not work. I have no...
you may have damage the main mother board. replacing the fuse,or regulators will not help.better to replaced the main mother board.and stay use the same hd and cd.but you may have to reload if you are not replacing with the same exact board. good lock
Dec 30, 2007 | Compaq Presario 700 470024-192 Notebook
No picture and thumping sound
I just had the same problem with my TV and looking on the web I found a site that helped. The site was www.freelists.org/archives/techassist/11-24/msg00326.html The entry said Raster NO GO / Pulsing sound from speakers / Poss ant relay clicks in time to the pulsing. It recommended replacing C816 and C5a28 (100uf /200v Caps) C5a03 (4.7uf / 200v cap) My set did not have the ant relay clicks and I could not fine the C816 cap on the circuit board and I didn't have the schematic. I found the C5a28 and C5a03 caps about the middle of the circuit board in the same circuit (around the metal L shaped bracket). The C5a28 cap was bad and the C5a03 cap was fine. I replaced the C5a28 cap and the set works fine now.
Oct 24, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
