Question about HP PSC 1510 All-In-One InkJet Printer
Wont copy Okay, well first of all i tried using the copier when it wasnt connected to the computer and the power button just flashed. i connected and installed it to the computer step by step, but for some reason it still wont copy or scan, the printer will work fine but it just doesnt seem to communicate to the scanner and copier part. im thinking more or less it's my printer and not my computer, please help.
  • 2 more comments
  • billi60 Nov 22, 2007
    hp psc750 prints fine,but wont copy
  • choti6 Dec 18, 2007
    i have 1510xi all in one printer . it prints well but whenever I tried to copy or scan I am getting whole balck page(some times with black lines sometimes whole blackish page.
  • Anonymous Jan 19, 2008
    my scanner used to work fine but I too am now getting a huge black page. HELP! I have tried everything...I may just buy a new one and say forget HP!
  • Anonymous May 11, 2010
    Verify your scanning bulb still lights when you try to scan a document, is the machine physically operating the scanning arm? Is it doing anything at all???? More information would be helpful but do keep in my mind you can get a very nice ALL IN ONE machine for between 100-125 bucks now.
    Genius:
  • 3,587 Answers
Drivers..drivers..drivers..
Here's a link to drivers for this model.
Posted on Feb 06, 2008
SOURCE:
Computer will not turrn on hp a 1230n
Hi Raul,
Try this following instruction to isolate the problem.
1. Check the power outlet/AVR if it has an output, if okay,
2. Check the wire if okay, often times, the wire is damage or open. try to use another cable.
3. If the wire is okay, try to isolate the power supply, remove the power supply connection to the board and short the color gray and green wire to see if the power supply is working, if the power supply turned on then its ok.
4. It the power supply is working, try to check the power on button, it might have a problem. to override the power on button you can short the pins inside the board where the wire from power button is connected to motherboard.
Jun 27, 2011 | HP Pavilion a1230n (EG134AA) PC Desktop
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
My green power button continues to flash and the printer wont print, what the deal?
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Aug 19, 2009 | HP Deskjet 6940 InkJet Printer
My Epson Stylus DX5000 won't work. All the lights are flashing and my comouter tells me to open it up and remove the "foreign" object. I can't see any foreign object and can't see hoe t open it up other...
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Feb 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer won't respond to demands
Hi cmiller59,
This is a quite common issue. Try this, un-install printer and printer software. Reinstall software first before you connect any cables. After reinstalling software power down your computer. Connect all cables associated with your printer. Power on your system, windows will detect new hardware and the wizard will ask you what you want to do. Place installation cd in the cd drive and in the hardware wizard choose have disk and click next. I hope this helps, if not, hit me back, we have other options.
Thanks for using FixYa.com
Sincerely, cyyyd7
Oct 09, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
GEPower Keyboard Help - Worked before, but not now
Did you install the CD software program for the Keyboard?
The Keyboard should have been plugged in before you started your computer. Then you should have installed the CD program.
Also after installation if it doesn't work try the following:
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Aug 06, 2008 | GE Power Keyboard (97798)
Need help urgently
Try unplugging the printer from the computer, then turn off the printer with the Power button, next unplug the power cord from the printer for 5 minutes or longer, now plug the power cable back in and turn on printer without connecting to the computer. If the lights have stopped flashing, reconnect to the computer (if using USB) or power off first if using a parallel cable.
Add comment if still having trouble. Hope this helps.
Mar 07, 2008 | HP DeskJet 930c InkJet Printer
No connection
try to manipulate device manager if you see a auknown device remove it, and restart your computer
Mar 06, 2008 | OKI C3400n Laser Printer
Installing my wireless keyboard and mouse
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Feb 20, 2008 | Micro Innovations KB985W Keyboard
Logitech ultrax
Make sure that your Keyboard and mouse receiver is plugged into the USB port before starting up you computer.
Then using the CD software program that came with the keyboard and mouse, install it.
After installation is complete and the keyboard or mouse doesn't work. Try the following.
Jan 10, 2008 | Computers & Internet
HP PSC 1510 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
