Question about Microwave Ovens
Panasonic inverter microwave combi makes a clunking sound after a few seconds and the plate does not revolve properly, the supplier said it was burnt on food on the spindle but how could food get there, I only remove the glass plate to wash it. Any ideas? Thank you Mgt.
  • 41 Answers
Check the glass plate lines up with the 3 notches on the spindle, if it's not sitting correctly it will clunk, it's just a matter of getting the plate to sit right on the spindle, if still no joy check to see if the spindle is damage or the glass underneath.
Posted on Nov 23, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Problem
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Nov 05, 2007
tiway1
  • 100 Answers
SOURCE: Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Posted on Jun 30, 2008
THENTHEREWER
  • 131 Answers
SOURCE: need a glass tray for sylvania
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY THIS IS THE ONLY PLACE I COULD FIND THE PART YOU ASKED FOR ,JUST COPY & PASTE THIS INTO YOUR BROWSER & YOUR THERE.YOUR MODEL # DOES'NT SEEM TO BE COMPLETE,THERE ARE LIKE 2 OR 3 DIFFERANT PREFIXES FOR YOUR MODEL.SURF THE SITE,ITS PRETTY SIMPLE.ITS A LITTLE PRICY,(62$)BUT I DID MY BEST,HOPE THIS HELPS!!!
Posted on Nov 08, 2008
SOURCE: cleaning advantium microwave
How do I clean the interior walls of the microwave over. Also any ideas about cleaning the glass on an oven.
Posted on Nov 28, 2008
SOURCE: need a manual for a panasonic inverter combi
my microwave is saying h98 what does that mean. it's a panasonic inverter.
Posted on Aug 20, 2009
Panasonic microwave combi oven model nn a772 sbbpq. I set the microwave for 12 minutes but forgot to put the meal in. It now works for a few seconds then stops. Any help would be appreciated
A thermal cutout on many ovens is black with two terminals. It's usually held in place by a bracket and one or two screws. Many ovens now use a thermistor instead of a cutout on the magnetron.
Based on the symptoms you describe, it seems unlikely either would be the cause of the problem. If a microwave is run empty, the magnetron will draw excessive current. The excessive current can take out the magnetron, high voltage rectifier, high voltage capacitor, fuse, or a few other components. If this is an inverter oven, check for a fault code of "H98" or something similar. That would indicate a problem with the inverter board, or something else in the high voltage circuit.
Feb 09, 2017 | Panasonic Microwave Ovens
Hi , in ur panasonic microwave glass tray is not revolving plz suggest what to do? thanks
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Nov 04, 2010 | Panasonic Microwave Ovens
The revolving glass plate on Panasonic NN-GD546 no longer revolve
the plate is controlled by a rotating motor.the motor is probably stuck or bad.
Feb 24, 2010 | Microwave Ovens
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Need a manual for a panasonic inverter combi microwave oven model number NNA514A
Aug 05, 2009 | Panasonic Microwave Ovens
I have a panasonic NNA883w combi microwave oven. The microwave part has stopped working. The unit dows not turn switches off after three seconds without warming anything. The oven and grill elements still...
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these inverter-based models.
You can find an authorized Panasonic servicer here.
Sep 25, 2008 | Panasonic Microwave Ovens
Even though these are different symptoms, the same part may be causing both.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Burnt Rubber Smell then Off
That would most likely be a problem with the inverter or magnetron.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Panasonic NN-H664 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
