Question about Electrolux Refrigerators
Candy wine cooler ccv-160 e12 flashing what does it mean
The cooler is still working but i can not cancel the e12 or reset temperature
2 Suggested Answers
  • 884 Answers
SOURCE: bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Check the condenser is clean, and the inside not iced up. Is there a fan inside? Check all is operating normally. When you say it is not cold enough, what temperature are you trying to reach? For keeping / storing wine, 8 to 10 c should be fine. For chilling before drinking, take the wine to a domestic fridge to get it to 4c
Posted on Apr 21, 2012
Candy wine cooler CCV 150BL will not auto defrost why
Hello Kim Carey,
Wine coolers are actually just like every other refrigerator
(just smaller (designs do vary)).
They even share common parts: AUTO DEFROST
is a very common point of failure...
I tried to pull up you "mini-frig" to offer parts houses (spares)
but got prices back in Pounds... (So I'm guessing you can have better success than I... from here (USA, Cali... SF/Napa)...
Try searching for spares with
"spares Candy wine cooler CCV-150BL"
In any case... Three things can cause a DEFROST FAILURE
- DEFROST TIMER
- HEATER ELEMENT
- DEFROST THERMOSTAT
If you can check your parts list... get your ORIGINAL
numbers from your manufacturer. BEFORE buying any parts...
If you want to trouble shoot there are some really easy things to check... Do take pictures before you start... a simple wire mix-up and your cute little wine cooler gets MAGICALLY turned into an expensive wine rack... (consider having a service person)...
((then break it yourself for free)).
The timer is a simple clock motor and a couple of contacts
(keeping in mind there are HAZARDOUS VOLTAGES and moving FAN blades inside MOST wine coolers ... Use a marker and put a dot on the timer center shaft (red in this picture) and the body... if those dots don't change (move apart) after a few hours your timer motor is the trouble... Take a picture and make noted of which color is on what TERMINAL.
I'm going to put up some USA PARTS as a visual aid
THESE ARE NOT YOUR PARTS...
and you will need a volt meter & circuit DRAWING to do further testing... Look right on the back of the COOLER or in your
original owners documents.
Comment me back if you want to continue...
There a very simple test you should perform before EVER putting a NEW DEFROST THERMOSTAT in your unit...
I'll be around. Good luck...!!
Be safe... (unplug that thing before putting your hand in there).
Oct 22, 2016 | Furniture
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
The temperature in my wine rack went under 12 Celsius does it means that my wine is ruined?
When it comes to cooler degrees the only thing you should be worried about is the time that will take your bottles to age. When the temperature is below 10 Celsius the aging process stops but there is no danger to your wine at all.
Aug 13, 2012 | Furniture
Can I install a thermoelectric wine cooler as a built-in cooler?
No. If a thermoelectric wine cooler were built-in, it would not be able to dispel the heat it emits and the fridge would not be able to reach the necessary temperatures.
Jul 31, 2012 | Furniture
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
What is a single zone wine cooler?
A single zone wine cooler allows you to store only red/white wine correctly. The cooler has only one temperature control and one space for storing your wines.
Bottles in candy wine cooler ccv 150bl are not cold enough even with thermostat is turned to cold is there any way to solve this
Apr 21, 2012 | Candy Refrigerators
The door was not shut good, so i turned the wine cooler off and defrosted it overnight, but i still have E5 error code flashing.
e-5 means that the unit is 10 degrees warmer then setpoint. If you just close everything up and let it run the e5 should disappear when it gets within the temperature.
Apr 25, 2009 | U-Line 15WC Wine Cooler
How to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
19 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
