Question about Radio Communications
Kenwood ts50 My Kenwood TS-50 has developed a strange fault in that when I press the PTT on FM, AM and CW the power comes up to normal then every couple of seconds it drops almost to nothing then comes up again, this repeats until I let go of the PTT. The radio has been used for my SSTV repeater on 14.236 USB for nearly 4 years with no problems until a week ago I noticed that the power was way down from the 50 watts that it is set for. Tapping the case, using freeze spray or a hair drier makes no difference. Regards, Les vk5zw P.S. my webcam for SSTV is at www.vk5zw.com
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
Hi Les, sounds like you have a hardware issue. Usually the power required to transmit is not readily available at your fingertips, so it is stored in capacitors. You may have some bad components in your Kenwood. Time to take it in for a review by a qualified repair tech. Unless you know what's going on inside the case, don't take it apart.
Posted on Dec 11, 2013
t1randa
  • 27 Answers
SOURCE: I just cannot reprogram this unit following the instruction manual..Help!
once you delete them i bielieve there gone radio shack does carry a book of frequiences you can program in depends on what you want listen to
Posted on May 27, 2009
SOURCE: My kenwood TK1118 cannot do manual frequency
you can press fuct and # ( St : 10 or 12.5 or 25 ) then adjust frequency like t5710
Posted on Dec 03, 2009
  • 211 Answers
SOURCE: Uniden BC80XLT Radio Scanner distorted
It may very well be an interference problem. While the scanner may not have moved, there are many items around it that may be the source of interference. Think back to the time when the interference started. Did you install something new around that time frame? Perhaps a new computer, a new monitor, some new CFL light bulbs? Any of these items can cause interference. The other possibility is that the interference is coming from outside your home or office. While these sources may not be able to be corrected, you can do a few things to help reduce the effects of the intererence:
1. Move the scanner to a new location. Radio waves are tricky little things. You may be able to find a location where the interference is weaker, but your intended signal is still adequate.
2. Try moving the antenna. If using the rubber antenna that came with the scanner, try laying the scanner flat instead of upright.
The other thing you may want to do is check the frequency with another scanner. There is always the remote possibility that the problem is with the transmitter, and not with your scanner at all.
I hope this helps. Good luck!
Posted on Feb 25, 2010
  • 99 Answers
SOURCE: I have been using the IC-R5 for a few years now
The occilator that "locks" the VFO (like a clock signal) is gong out of range. The higher temps are affecting the temprature controlled occilator. I would send the unit to ICOM for repair.
Posted on Aug 31, 2010
  • 6 Answers
SOURCE: My Uniden BC92XLT will not
Does it just sit on one frequency? and not scan any others? and if you turn the volume up all you get is white noise?
Posted on Feb 27, 2011
How do i turn off the tnc indicator on the ts2000
per the manual the main band is the default for the built in terminal node controller you may have to change it manually by pressing the vfo A or B.
Oct 24, 2014 | Kenwood TS-2000
Whats the Wiring JCD-201M to the Kenwood TS-2000.
(2000) (201M)
1- mic in 1 - Shield gnd
2- PTT 2 - Mic in
3- U 3 - Mic gnd
4 - D 4 - PTT
5 - +8 5 - U
6 - rx af 9some models) 6 - D
7 - mic gnd 7 U/D gnd
8 - gnd 8 gnd
Enjoy
Sep 07, 2014 | Radio Communications
Why does my Kenwood TS 790 E when pressing call button causes C2 fault on display?
http://www.iw2nmx.it/Kenwood%20-%20Trio/TS-790%20Instruction%20and%20Service%20Manuals%20plus%20mods/TS-790%20Instruction%20Manual.pdf
Jul 14, 2014 | Kenwood Radio Communications
I bought additional kenwood tk 2100 radios and they are not sending the signal to my existingones. The fcc numbers and interior tk numbers are the same. How to I get them on the same frequency.
To change the channel frequencies on your TK2100, simply press and hold the PTT switch ("talk button") and Monitor key, then turn the power on. Now press the PTT switch again. The light should change from orange to red and a beep should sound. Next, adjust the channel switch to the channel you wish to program. Now simply press the PTT button to choose between 4 to 8 possible frequencies, depending on your model.
You can find the manual and frequency graphs here: http://www.heritageresale.com/documents/TK2100OwnersManual.pdf
Aug 26, 2011 | Kenwood...
Heil microphone gm series wiring diagram to suit kenwood ts 450
This is the pinning of the GM-series.
pin 1- Ground / shield
pin 2 - Mic (audio)
pin3/4 - PTT
On the 450 the next;
pin 1 - Mic (Audio)
pin 2 - PTT
pin 7- Ground (Audio)
pin 8- Ground (PTT)
Good luck,
Gerard
Jan 21, 2010 | Heil Sound PR-40 Professional Microphone
Front panel turns off
Have you performed a FULL reset on the TS-2000?
To perform a full reset:
With the power off press and hold down the A=B button and with the other hand turn on the TS-2000.
After that you will have to press the A=B one more time. The radio will reset itself,
and the display will show 14.000 MHz in the main band, and 144.000 MHz in the sub band.
Please let me know if it worked for you.
Tommy
KG4TDM @ arrl .net
Sep 12, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
Lightning happend, not far away.
dear Sires,
Sorry i am not finished yet with my TS-440S. I have found that TXB and RXB supply signals are present in same time. Transistor Q35 from IF UNIT was burned thru. Now the trasciever works in all modes excelent, but just on the 3,5, 7, 10 and 25 MHz band. I am looking for next damage away, but i have a little problem. I became a pacemaker last week, and must keep my right arm a vile.
With regards
M.Galovic 9a5amg
Jul 06, 2009 | Kenwood Audio Players & Recorders
TH-79A amateur radio
TH-79A Kenwood HT and with the power off, hold down the MR button and the PTT switch, and while holding both of these turn on the power. The HT will come up in the remote control mode with the display indication "RC" on one band and the normal display on the other band.
To get the HT out of the "RC" mode just repeat the MR+PTT+Poweron sequence
Oct 30, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Kenwood ts-450s - cannot tune and no ptt
This is usually due to a stuck or shorted ptt line. I have repaired a couple of these and it was the same component each time. The packet TX transistor Q65 shorted causing the radio to power up in TX inhibit mode. Transistor Q65 is located on the underside of the IF board under the ACC 2 connector. This switching transistor is used only for tx (pin 9 of acc 2) and no other circuits depend on it. It can be removed completely if you don't mind not having ptt on acc 2.
This seems to be a common problem lately, I hope this helps you.
Apr 26, 2008 | Radio Communications
Radio Communications Logo
138 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
