Question about Worldwide 1997 Saturn SC Series 1.9L Alternator - 96 Amps
After replacing clutch my saturn 1.9 is hard to shift
After replacing clutch it is hard to find gears. Also seams to have lots of play in the pedal
    Sergeant:
  • 192 Answers
Check your pedal adjustment. If there's too much play it could be not engaging the clutch, which will make it difficult to find the gears.
Posted on Nov 23, 2013
I am having trouble keeping enough clutch pedal to shift gears What cause no clutch pedal on 2007 saturn I O N
you may need to bleed the line...you may have air in the line..
when they replaced your clutch they may have forgot to bleed your clutch line.
Jul 22, 2017 | Saturn Cars & Trucks
How to adjust the clutch on a 1999 Ford escort ZX2
The clutch is not adjustable it is fully hydraulic. That means it is self adjusting, if the clutch pedal engages high on the pedal and the clutch is hard to push you need a new clutch plate and pressure plate.
Mar 18, 2017 | 1999 Ford Escort
20004 Saturn i am having shifting problems will not go into gear smoothly,if at all . 5th gear in nearly impossible to find with out grinding . Is it the shifter ,clutch or clutch pedal not engaging?
Possible causes are: The clutch is going out, the hydraulic clutch system is low on fluid, or the transmission input shaft is binding on the pilot bearing. 1. Is the pedal firm and does it feel like it used to? (low fluid). 2. Once in gear and moving push on clutch and notice when the transmission disengages. If it does not disengage until the pedal is almost at the top then the clutch is getting thin and will need replacing. 3. With vehicle on a smooth flat surface, depress clutch and try to shift into any and all gears. Notice if vehicle tries to lurch forward as shifter goes into gear. This may be a subtle lurch but should be noticeable. This checks for a binding pilot bushing. Let me know what you find. Thanks and please rate.
Sep 05, 2011 | 1999 Saturn SL
1998 Saturn SC1 manuel stick is hard to shift into 1st & 2nd gear
Try to double clutch the clutch pedal. How to double clutch; push the clutch in moving the stick to neutral, then release the clutch and then push it back in and shift into first or second gear. If it works then it is not the shift linkage and could be a clutch adjustment. First how far do you have to release the clutch pedal until the clutch plate starts to engage? If only an inch or so the clutch pedal needs to be adjusted, which is an easy fix (this is more common). The other possible problems could be the clutch plate, throwout bearing of syncros could be bad. If it is one of the previous problems double clutching should buy you some time.
Jul 01, 2010 | 1998 Saturn SC
2002 saturn vue, manual shifting problems
You have a slave cylinder for this trans. Pump the clutch pedal 25 times with the engine OFF. Then start it and try shifting it into each gear while parked. If this make it work your slave cylinder needs to be replaced
May 15, 2010 | 2002 Saturn VUE
Replaced clutch but now hard to shift into gear. will go but hard to shift. heard there was a safety on these that if brake lite not coming on will not go into gear properly.
If it's going into gear hard it's most likely because the clutch is not disengaging enough. Do you have a lot of free play? Does the clutch start to grab with the pedal real close to the floor? If so, check the the nylon bushing under the dash where the pushrod for the clutch master cylinder attaches to the arm. Is the pedal real spongy, is there air in the hydraulic system? Another posibility is that you damaged the pilot bearing causing it to drag and it keeps trying to turn the trany. If you get the rolling a little then try to put it into gear, will it go in easier? If so the clutch is dragging. There is nothing with the brake lights that will cause it to shift hard. With an automatic trany the brake lights will unlock the torque converter. Also with a 4X4 and automatic trany and electric shift on the transfer case, the transfer will not shift unless the trany is in "N" and your foot is on the brake. There is nothing on a manual set up that anything to do with brake lights and shifting.
Nov 24, 2009 | 1996 Ford F150 Regular Cab
Hard to Shift Gears?
How is the clutch adjustment?
Is it releasing fully?
If you have a hydraulic clutch....is the brake fluid level in the clutch master cyl beside the brake master cyl full?
If you have the cable clutch.....is there only 1/2 inch of play..... if you pull up on the cable at the transmission end of the cable?
Aug 31, 2009 | 1996 Saturn SL
1993 saturn sudan when clutch is interacted shift stick will not go into gear
possible clutch pedal hydrallics.If the clutch pedal has alot of freeplay before pressure,it will not produce enough travel to throwout clutch pressure plate which needs to fully disengage to switch gears while running.
Jul 12, 2009 | 1993 Saturn SL2
Shifting problems
start with the clutch fluid, is it full? check the clutch cable from the pedal to the transmission, does it have a lot of play in it, is it adjustable? check the bushings on the shifter base, does the shifter itself have a lot of play in it? i'd start with those, if all those are ok then it might be the clutch itself. when a clutch gets worn down it doesn't release fully causing a hard shift or grinding when going into gear. put the truck on a flat surface so it doesn't free roll at all, with the engine off, put the truck in first or reverse, press the clutch pedal fully to the floor and start the engine. let off the brake. if the truck moves at all it means your clutch cable is out of adjustment or its just getting worn out. provifing the shifter and the fluid level is good.
Feb 16, 2009 | 1995 Toyota Tacoma
Worldwide 1997 Saturn SC Series 1.9L Alternator - 96 Amps Logo
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
