Wireless button wont turn on
I have tried pressing the button to turn the connection on but it still wont turn on
    New Friend:
  • 9 Answers
What is the name of the device and serial number. I can look it up or you could try to make sure that the device is plugged in, after that find a pin and hit the reset button, and/or make sure that the device is actually connected effectively.
Posted on Nov 26, 2013
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
Trying to connect to a ps3. Lights flash but wont sync
plug the controller into the ps3 and then try it..... a lot of times if you unplug the ps3 it wont recognize the controller next time you turn it on this should help
Apr 14, 2009 | Sony Wireless Controller for PS3
Xbox 360 wireless controllers wont connect!
well you might want to press the little button by the battery pack at the top and the little one on the 360
Mar 01, 2009 | Microsoft Xbox 360 Wireless Controller
Wireless controller flashing green light but wont detect xbox360?
Have you tried resyncing your xbox and controllers? On the controller, press the little circle button on the top of the controller, between the bumpers. On the 360, there's a small circle button, about half inch wide, next to the memory card ports. Press that as well.
Jan 05, 2009 | Microsoft Xbox 360 Console
Red light wont go off headset wont turn on
SImply connect the headphones to a power source. Then press up and down volume buttons at the same time. It will reset the headphones.
Dec 08, 2008 | Insignia Bluetooth Wireless Headphones...
My Toshiba Satellite PSL30A-00100E wont pick up wireless LAN
there is a switch on the front of the laptop on (just under the mouse) on its "face", it just says on off
Nov 28, 2008 | Toshiba Satellite L25-S119 Notebook
I plugged in my usb for my hp wirless optical moblie mouse and for some reason the light on the usb wont blink it just stays on I even press both the buton on the usb and the mouse that sais connect and it...
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 12, 2008 | HP Wireless Optical Mouse
My wireless contoller wont connect
If so, it really sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Oct 16, 2008 | Microsoft Xbox 360 Wireless Controller
Not working properly
Are the batteries good in the mouse?
If they are try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
May 28, 2008 | Belkin Mini Wireless Optical Mouse...
HPL7780 and Linksys WRT54GS V7
That usually happens when you are going to connect the printer PRO using the wireless. To avoid that problem, try connecting the Printer using the Manual Setting of the IP.
Solution
NOTE: If the router has an outdated or firmware that was not supplied by the manufacturer, update the router to the latest manufacturer-supplied firmware. Set a Manual IP address on the HP All-in-One
  1. Change the IP settings to Manual from the HP All-in-One.
    1. On the front panel of the HP All-in-One, press Setup .
    2. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Network , and then press OK .
    3. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Advanced Settings , and then press OK .
    4. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select IP Settings , and then press OK .
    5. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Manual , and then press OK .
  2. Set the IP settings from the Manual IP Settings menu using the following instructions. For this item... Do the following... IP Address Type a manual IP address on the same subnet, but outside of the DHCP range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway.
  3. Run the Wireless Setup wizard and try to associate the HP All-in-One to the wireless network.
Workarounds Connect the HP All-in-One via a Wired Network
  1. Disable Wireless Radio. Follow these steps to turn off Wireless Radio.
    4. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Wireless Radio , and then press OK .
    5. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Off , and then press OK .
  2. Connect an Ethernet Cable to the RJ-45 connector at the back of the HP All-in-One.
  3. Connect the other end of the Ethernet cable to one of the LAN ports of the router.
  4. Turn off the HP All-in-One by pressing the Power button. Turn on the HP All-in-One again.
Connect the HP All-in-One via Ad Hoc Wireless Network
  1. On the HP All-in-One control panel, press Setup .
  2. Use the down arrow button (c01155210.jpg ) to highlight Network , and press OK to display the Network menu.
  3. Use the down arrow button (c01155210.jpg ) to highlight Wireless Setup Wizard , and press OK . The Setup wizard searches for available networks, and the color graphics display shows a list of detected wireless network names (SSIDs).
  4. Use the down arrow button (c01155210.jpg ) to highlight your wireless network SSID, and press OK . If any encryption is configured in the computer, the wizard will prompt for the WEP key.
  5. Highlight the letter or number on the visual keyboard, and press OK .
  6. Highlight Done on the visual keyboard, and press OK .
  7. Press OK again to confirm the settings. The HP All-in-One will try to connect to the wireless network. Once the wireless network is successfully setup, a message should appear stating that the connection has been successful.
  8. Press OK .
Source: www.hp.com
To get the technical document click here ==>> Document
Please let me know if the issue wont resolve the problem so that we can go ahead and do another workaround.
thank you.
adonscott
Aug 21, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
