Question about Minolta Office Equipment & Supplies
I have a minalta cs pro ep 1085..when I tried to take copy the paper jumed and errore code apeared (c0010) ,, any help will be greatfull
  • Minolta Master
  • 6,161 Answers
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it. Hope this works for you
Hope this works for youH
Posted on Jan 22, 2015
5 Suggested Answers
SOURCE: service
After replacing the waste toner bottle you must reset the waste counter(in copier maintenance mode) to make the error go away.
Posted on May 21, 2008
Cogz
  • 1326 Answers
SOURCE: code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Posted on Feb 07, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Posted on Oct 17, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: my copier minolta cs/pro ep 2010 does not
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Posted on Mar 20, 2010
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
Minolta cs pro ep 1085 errore code c0010
Nov 23, 2013 | Minolta Office Equipment & Supplies
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Apr 18, 2012 | Minolta Office Equipment & Supplies
I have a minalta DI350 when I turn machine on the error c0010 come up seams that the motor is trying spin but can not can you help
remove the drum cartridge check the mechanical gear in that assy. try to rotate all the gears if its ok try to check the mechanical parts at the back of the machine to check the parts remove the back cover of the machine then inspect all mechanical gears & motor
Mar 27, 2011 | Minolta Office Equipment & Supplies
Minolta Copier EP 6000 copier error codes: C:C0010, C:C0992, C:C0410. Any ideas what these mean?
As for the C0992 code that deals with a paper draw fault, looking at the control panel do you see a small wrench located at the left hand lower corner. Touch it , it will take you to another screen when there open and close the front door, if the code comes back you have problem with main draw.
The C0410 is a problem with the very, bright lite under the big glass is bad. try to reset, open the front door to your left is a small access plate open and press trouble reset, if the code comes back replace the exposure lamp.
C0010 code main motor fault, remove the fuse unit the hot part and check for broken gears check the section where it goes look in the back for broken gears, remove the drum assy. check for broken gears, open close the front door to reset, If it comes back get a new main motor and or main control board,
Dec 03, 2010 | Minolta Office Equipment & Supplies
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Ep 2030 error code c06
Exposue lamp, does the lamp come on under the glass at all. Open close the front door, if that code comes back your exposure lamp is gone. Thats the bright ligh that comes on while making copies.
Jul 16, 2009 | Minolta EP1030/1030F CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Nov 15, 2007 | Minolta EP1030/1030F CS/PRO Copier
24 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
