Flyback spark when power on then under the flyback sparking
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
The potting insulation has failed and you need to destroy this monitor. Free ones are available in the free section of craigslist.
Posted on Nov 24, 2013
1990 F150 6cycler no spark
check to see if you have voltage to the coil with the ing on .. if no volts need to check fuses and relays some under hood and under dash drivers side
Feb 19, 2013 | 1990 Ford F150
No spark on a 1998 Chevy venture
Hi orvil brad hear I would check the ing. fuses you have at least one and maby two in the inside cab fuse block, and also one or two in the engine bay fuse panel, there is also a relay located in the eng. bay panel, also you may check the ing. wire that goes to the coil system, This wire will have no 12volts until the ing. switch is turned on then it will show 12volts. It has a habit of coming loose at the coil sometimes. Good luck
Dec 30, 2017 | 1998 Chevrolet Venture
OMI HAVE A 1900 K1500 5.7 AND I' M NOT GETTING ANY SPARK OR GAS I HAVE CHANGED THE DIST., COIL, ING. MOD., CAP BUTTON AND CPU. ANY SUGGESTIONS
did u check the switch that shuts off the spark and gas should b under kick pnl rt side there is a reset button push it in try that
Apr 04, 2011 | 1990 Chevrolet K1500
Truck turns over but wont start
Possible problem ing switch its the electrical s/w that key turns. gm has had problems w/ this s/w.. new one 100 bucks. check under steer ing column larger red wire w/ yellow stripe power goes in does not come out of s/w like it should. characterized buy engine turning over .. But no dash lites air bag oil check etc..good luck..
Mar 24, 2011 | 2000 Chevrolet Silverado
LOOKS LIKE HIGHVOLTAGE WAS JUMPING ACROSS A COLD SOLDER JOINT IN THE FLYBACK VICINITY...RESOLDERED LEG AND THE TV ATTEMPS LIKE 3 TIMES TO POWER UP TO NO AVAIL?HELP!
sometimes when shorts or sparks occur in the viciity of the flyback. compnents take a hit. if i had this set in my shop i would first check what is called the horizontal output transistor. this transistor is directly related to flyback and i would suspect it to be shorted. certain capacitors and diodes also can short under the same situation. And theres a possiblility that the flyback is bad
Oct 14, 2010 | RCA HD52W59 HDTV Projection Television
Has no spark. replace the control module and still no spark
first check for power at distribuitor terminal if pwr replace ing coil, if no power check ing switch, also a common problem is some one accidentally cause a spark or short one of the fuse links by the starter may be open check them all.
Sep 29, 2010 | 1988 Oldsmobile Delta 88
Power supply sparks when tv is turned on
That can either be the Flyback or the HV splitter. The flyback is located on the lower left hand side when looking in the rear and has a large red cable coming out of its top. The HV splitter is located in the front in the center of the set. These are both very easy and inexspensive to replace. I can post a link where you can get replacements with instructions.If you would like.
May 08, 2009 | RCA D61W20 61" Rear Projection Television
52" GE tv problem
sounds like the flyback, That model is famous for thr flybacks burning through. If it is indeed the flyback thats a repair which is easy and you could do it yourself for under 50.00 Go to the following link leave them a email with your model number and sympton they have your flyback for less than 50.00 with free shipping and free tech support. Your model uses flyback number 265409
here is the link.
http://servicemanuals.vstore.ca/
Jun 28, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
WHEN PUSHING THE ON/OFF SWITCH ON THE FRONT OF THE TV, THE BACK OF THE TV AT THE POINT OF WHICH THE POWER CORD ENTERS THE UNIT, MAKES A CLICKING OR SPARKING NOISE AND THE HIGH PITCH AIRY SOUND TV'S HAVE...
Sounds like the flyback is arching. i would suggest looking the flyback over for signs of arching. You may need to replace the flyback. If you need to know where to get a replacement let me know and I will post a link along with the correct part to order.
Jun 08, 2008 | Televison & Video
RCA D52W20
the flyback is the transformer with the RED wire that resembles a spark plug wire you can get one at the following link for under 50 dollars and comes with free tech support by way of on line instant messageing. They sell that flyback which is a part prone to failure. Its the only RCA flyback that they stock. Heres the link.
Apr 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
