Question about HP PSC 2210 All-In-One InkJet Printer
Scan error I have a hp psc 2210 all in one and about every half hour or so I get a scan error report, and if I am away from my computer for any length of time I have a dozen error codes envolopes to delete before I can do any work????????????
  • 1 more comment
  • Anonymous Dec 29, 2007
    I receive error, 'An error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try again' approximately every 15 minutes. If I leave my computer running I will have several of these Errors.
  • ginlegg Jan 01, 2008
    I have a new computer with Windows Vista installed. I reinstalled my printer from the installation disks that came with the printer and now, an error message comes up saying that the scanning device is not working and this message repeats about every 30 minutes.
  • Anonymous Jan 01, 2008
    I also receive the scan error and my scanner will only work if operated through my computer. I can not get it to scan from the scanner.
Could you please provide me the exact error message you find on the screen.
Posted on Oct 10, 2007
SOURCE:
How do i use my scanner for hp psc 2210 series.... I trying to scan something. I have pushed the scan botton on the printer. And i can't scan anything.....
The reason may be that the software is not installed properly. Did you try to scan from computer?
From computer you can try from Hp Director/ HP Solution Center or from scanner and camera wizard.
Mar 29, 2011 | HP PSC 2210 All-In-One InkJet Printer
How do i scan with hp psc 2210 ? It says it is saving it to hp gallery but cant find it on computer
Uninstall printer and reinstall. This printersoftware is pretty vulnerable. If nescessary, get the driver from www.hp.com and run from there. You can probably scan from a picture editing program like PhotoShop or others like it. File>Import>twain - and your psc 2210.
Mar 05, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP all-in-one 2200 series printer doesn't work w/Vista
For scanning you can go to Paint/ File/ from scanner or camera
Regards from
[email protected]
Dec 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
The scan part on hp psc 2210 all in one wont work, i install my printer from the net
Hi there. You can only use the scan option by phisically connecting the printer to a computer. If you share a printer on a LAN and connect it to another computer to use, it won't allow you to use the scan option. This option is not supported on printers shared with another computer. If you installed the printer on a LAN with a print server, make sure the server can support the scanner drivers, otherwise you can't scan.
Good luck
Nov 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all in one printer
You can't load the software that came with the printer.
HP has a Vista page for your printer. Here is a link: PSC2210 Using Vista
Basically, you need to uninstall the software AND delete the printer from your computer. Disconnect your USB cable. Power up your printer. Connect the USB cable.
The above link gives some workarounds for scanning and importing images.
Nov 07, 2008 | HP PSC 2210 All-In-One InkJet Printer
Scanner failure during the initalization/starts up.
Sound as if your scanner is broken..
Could be something in there stopping it from moving, the motor could be bad.
It might have Home Positioning errors, causing this error.
To get it Fixed? The machine is about 140 dollars on Amazon?
The company I work for, the first hour is 125 (I do not know how much it cost to repair these)
Unfortunately these little ink jet printers are not designed to be repaired. They are considered throw away.
Sorry
Oct 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Problems
Switch the unit. let it rest for half an hour. While it is resting check the manual for any 'faults' list. Look for a 'reset' command - may be mean pressing several buttons while the machine is off and then with the buttons still pressed switch on the machine[you may need two hands and a nose or three hands for this ;-)] If still out of luck go to places for further info HP technical support team or www,fixyourownprinter.com
Jul 05, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
73 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
