Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Troy Bilt lawn mower
I have oil leaking into the air filter. I'm not sure what to do.
  • Diane Cyr
    Diane Cyr Nov 23, 2013
    I have a Troy Bilt model 11AA26M011. It runs great, starts easy. Oil level is good. While mowing the lawn it started smoking and oil started coming out of the air filter leaving a small puddle of oil. I cleaned everything up and it ran fine. After mowing the lawn several times with no problem it did it again.
  • Craftsman Master
  • 2,478 Answers
Check oil level, maybe overfull
Posted on Nov 23, 2013
  • 151 Answers
SOURCE: I have two craftsman lawn mowers that will no
it sounds like you have compression but the fuel air mixture is out of setting. This could be due partialy to a stuck fuel needle or mixture needles that are worn or out of allignment. If you could give me the model # on the unit i could help with the type of carb and the inital settings on the mixture needles.
Posted on Dec 24, 2009
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
hunter19_46m
  • 7482 Answers
SOURCE: i have craftman lawn mower it has honda motor
Hi islamamin200..
You have a problem with the inlet float, there is something holding it from closing totally.
When you cleaned the carburetor did you clean it with a cleaning solution such as lacquer thinner, this is used to cut the "varnish" buildup in the jets and needle valves of the carburetor.
Follow the directions below:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 26, 2011
heatman101
  • 43501 Answers
SOURCE: My lawn mower won't start. It needs oil. It
Yes... most have oil sensors which shut them down bwfroe damage is done...and if not what can it hurt now???
Put oil in it and try it..
heatman101
Posted on Aug 04, 2011
#1 Taper
  • 1040 Answers
SOURCE: Craftsman 675 Torque 190cc 21"
If your carburetor has sat for a few months with fuel in it, the fuel may have gone bad. Fuel turns to turpentine after a while and leaves light yellow deposits behind. These deposits will keep your carb. from working properly.You need to dip the carb. in carburetor dip for a few hours to get rid of the deposits. You can also take the carb. to your local parts store where they may do it for free.
You may also have to replace the gasket and needle valve too if it has been sitting. So basically, you need to do a carburetor rebuild.
If the float sounds like it has liquid in it, you will need to replace it too.
Good Luck!
Jim
Posted on Aug 13, 2011
Oil coming out of air filter
Look for a crankcase ventilation tube or such, It may be covered with grass dust and stuff, is probably a sponge to keep dust out of the motor. Rinse it out, and make sure the airway is clear.
Nov 24, 2013 | Garden
My troy bilt lawn mower does not want to start like it loses priming. Can I reprime manually
if it has a bulb pump it about 20 times if not you could spray a little starting fluid in the air filter or take filter off and poor a little gas in the carb
Aug 03, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Troy-bilt 34322 343220110815 mower will not start
Dump out old gas. Fill with fresh gas. Always use Stabile in gas. Clean or replace park plug and air filter. Check oil level. All mowers have a low oil start cutoff. 30w oil. If any grey in oil moisture contaminated, dump out old oil and refill. Check fuel line for cracks or leaking. Check primer bulb for cracks, replace if required. Clean outside of carb with carb cleaner to ensure easy choke operation. Remove carb bowl from carb, ensure float hangs down freely. float down fuel flow, float up fuel flow stops. Check bowl screw for hole thru bolt, if so clean out hole.
Sep 11, 2012 | Troy Garden
TROY-BILT TB525 EC 4-cycle Gas Trimmer+how to fix oil leak
Oil runs back out of the carburetor air filter intake if I fill to oil level indicator on no oil gas mix engine. Anything wrong or am I just over filling the oil?
Jun 28, 2012 | Troy-Bilt Garden
The engine smokes excessive. the mower is 2 yearsold.
Sounds like the mower has been tipped, the engine breather is on the top of the engine, if the mower is tipped on its side oil will tavel down the brather pipe into the back of the air filter box, the filter is paper and once soaked in oil it will smoke heavily, remove the filter cover and filter, run the mower ( not cutting grass ) until the smoke stops, now replace with a new paper filter, check the oil level in the engine, if low top up.
Jun 21, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower 6.75 hp smoking too much oil
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
May 19, 2010 | RTO Lawn Boy 6.75hp Mower
Changing oil in a troy bilt squall 5521
To change oil in a lawn mower you will need to acquire a fluid evacuation pump. Remove the dipstick and with the pump evacuate the old oil into a suitable container. Check your owners manual to determine how much oil to put in DO NOT overfill or the mower will not work. Make sure the old oil gets recycled.
Oct 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Won't start after 3 seconds it stops
try changing or cleaning the spark plug and scoket
Aug 18, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
106 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
