Citroen c3 headlight
Blulbs and fuses are ok, but dip beam does not work
    Champion:
  • 219 Answers
Check the plug. Could also be a relay
Posted on Nov 27, 2013
2 Suggested Answers
SOURCE: citroen c3
its fuse F14 in the fuses under the bonnet you have to remove the battery cover to take the lid off its a 10A fuse
Posted on Apr 15, 2009
Citroen c3 headlight stop working left side only
Left dipped beam Fuse 9 rating 15 A
Right dipped beam Fuse 10 rating 15 A
Both fuses in the fuse box under the bonnet
Dec 31, 2014 | Citroen Cars & Trucks
Citroen picasso
CHECK FOR LOW/DIPPED BEAM FUSE BLOWN IF OK CHECK BULBS
Jan 12, 2014 | Cars & Trucks
I couldnt choose Citroen in the option so please discard the audit etc. I have a CITROEN C2 VTS (NU57 XSG) and have replaced the original headlights with Citroen (morette) twin headlights, i am wanting a...
loop the main beam to the second light simple ,find the feed with a meter when the main beam is on ,simple to do but be warned here ---make sure the light has a certificate of homoglonation and a E number in the headlight glass or you could face a big fine for unauthorised modification of a motor vehicle ,also this sort of work can only be signed off by a authorised garage with a Value Added Tax certificate and a inspection to change the cars papers at the local car testing station ,or dont drive in spain as they will impound the vehicle
May 06, 2011 | Audi TT Cars & Trucks
Golf gti mk3 dipped headlights not working,fuses ok bulbs changed
If high beams are working and the dipped lights not it is usually the headlight switch that is faulty and will need to be replaced.
Jun 13, 2010 | 1995 Volkswagen GTI
No dipped beam headlights on audi a4 1,9td 2003
Check up dipped beam headlights fuse inside fuse box. For Audi A4 the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram. If the dipped beam headlights fuse is OK, check up dipped beam headlights bulbs.
Dec 28, 2009 | 2004 Audi A4
97 f-250 low beams will not come on
Check the fuse and relay.If they are fine then change the switch.
Sep 16, 2009 | 1995 Ford F250
98 honda accord headlights not working!
hi is the problem with dipped beam? or do h/lights on both dip and main beam not work ? do all side and rear lights work ok ? have you checked fuses? left and right heanlights have seperate fuses as do side/tail/rear lights also there is a relay in fusebox for dip beam and one for main so if you could supply any more info as to above querie? it woul help to advise on possible fault and possible remedy hopefully DIY best wishes
Oct 26, 2008 | Honda Accord Cars & Trucks
Dim headlight
This is always caused by a loose or corroded headlight ground wire, check around the head light for a wire screwed to the sheet metal or radiator support.
Oct 02, 2008 | 2001 Toyota Tacoma
Low beam headlights do not work, but high beam headlights do
Clyde,
I've been troubleshooting this same problem on a different vehicle this week, and I can give you the steps I'd take.
1. If both sides went out at the same time, the problem is *NOT* likely to be the bulbs.
2. Check the fuses to see if both low beam lights are on the same fuse. Many cars have one fuse for low beam and another for high beam, so both lights out at the same time typically means fuse blown.
3. If the headlights are OK and the fuses are OK, then the problem is *LIKELY* the headlight switch. In my case, AutoZone has one and it can be installed easily; but in your case, that may not be as simple.
Please post your findings or comments.
Jul 16, 2008 | 1991 Nissan Pickup
Computers & Internet Logo
David Payne
David Payne
