Question about Adobe Photoshop CS6 Extended - Windows
Preset brushes some are missing!
  • 281 Answers
Have you tried reinstalling Photoshop?
Posted on Nov 23, 2013
Testimonial: "noooooo! jhajaja, i haven't as soon as i finish this deadline i'm on i will...this was my first reasonable solution too, just wanted to see if anyone had the same problem. i'll keep you posted!! thanks for your comment!"
The electric toothbrush I have received seems to me is secondhand because one of the four brushes is missing and is already charged.
Batteries are always partially charged prior to shipping. The missing tooth brush would normally be replaced if you notify the seller of the shortage.
Aug 16, 2017 | Electric Health & Beauty
Motor undefined
It sounds like your motor is going bad. When an electric motor has some age, the motor brushes will wear out and fail to make contact inside the motor. The missing sound you are describing is probably a burnt spot on the armature where the brushes are not transferring electricity. If the unit is an expensive unit, you may be able to order replacement brushes for the motor, or even better.... a replacement motor
Sep 27, 2014 | KitchenAid K45SS Classic Stand Mixer
I compair it to a gas motor with a miss.
Could be a few different things. Have you checked the motor brushes? Check they have plenty carbon left on them and that the spring is in good condition. Make sure they slide through the Brush Housing smoothly. Sometimes a sticking brush or bad contact can cause intermittent power loss.
Jul 22, 2014 | Pride Revo 3 Wheel Scooter
Where is factory preset code for keyless entry on 2011 Ford Escape located
most of the time the will give you the code. it takes a scan tool to pull the code out of the computer but there may be a way to change in the owners manual
Mar 18, 2013 | 2011 Ford Escape
In photoshop shape dynamic is again and again missing
If you are drawing with brushes.
With the exception of the pen tool, the brush tool is the most versatile tool in Adobe Photoshop's arsenal. There are a multitude of tasks for which you can use the brush tool. including retouching, freehand drawing and stamping. However, in order to truly exhaust the brush tool's potential, you need to understand how to change your brush style, import brushes into your toolbox and make your own brushes.
Changing Your Brush's Size and Shape b> To change your brush's and shape, press the F5 key on your keyboard to open up the brush window. A number of pre-formatted brushes will appear, along with a menu of options you can use to customize your brush. Choose the brush that best fits your preference by clicking on its display square on the right-hand of the brush window. Use the sliding bar under the heading "Master Diameter" to increase or decrease your brush's . You can further change the texture, shape or dynamics, or further stylize your brush, by checking any of the boxes in the brush window's tip shape menu on the left. b> Importing Brushes b> You can download custom brushes from the Internet in variety of styles and shapes. To load a brush set you have downloaded, select the brush tool in the basic toolbar and click the small arrow next to the brush indicator at the top of the screen. Click the arrow next to the indicator to open the brush menu. Choose "Load Brushes." When the file selector opens, choose your new brush file--brush files will always have an .abr extension--and click "Load." Your new brush set will be added to your brush palette. Creating Your Own Brushes b> Before creating your own brush, you need to have an image or freehand drawing that will serve as the basis for your brush. Brushes can be simple or incredibly detailed depending on the image used to create them. To make your brush, open the file containing its design. To make the best brush possible, it may be necessary to tweak the file. If you are using a color image, convert the image to grayscale by choosing the "Image" drop-down menu from the top of the screen and choosing "Mode" and "Grayscale." Select "OK" to discard the color information. Continue to tweak the image by choosing the "Image" drop-down menu again and selecting "Adjustments" and then "Levels." Using the slider bar at the bottom of the screen, adjust the settings until you achieve an image that has a sharp contrast between its black and white portions. Once you are happy with the image, choose the "Edit" drop-down menu from the top menu and "Define Brush Preset." Name the brush in the pop-up window that appears. You can now use your brush and further customize its shape and style by using the basic brush preset manager at the top of the screen. Hope this helps.
Dec 22, 2012 | Computers & Internet
Claning brush missing
You can call Norelco customer service to see if they will send one. The number is 1-800-243-3050.
Or, you can purchase one from shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-accessories/norelco-shaver-cleaning-brushes-2-brushes-p-256.html
Dec 23, 2011 | Philips RQ1150 SensoTouch Rechargeable...
I`ve entered the code i was given for my philips bmw business rds PH7850V1303828 (code given was 8396) but nothing happens! am i missing something?
8396 is the correct code for that Serial Number.
Here are the Code Entry Instructions
Philips DC785/24E BMW Code Entry
After switching on the unit the display will show ' CODE - - - - '.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Followed by pressing the ' > ' rocker key.
The set will now operate.
Oct 02, 2009 | Philips Car Audio & Video
Missing preset positions o SNC-RZ30P IP Camera
in the rear camera have the reset, turn off the camera and turn on the camera and holding the reset button.
sony tech: lgzoe2@gmail.com
Jul 08, 2009 | Sony SNC-RZ30N Network Camera
Adobe Photoshop CS6 Extended - Windows Logo
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
