Question about Champion Sportline Solo 900 Heart Rate Monitor Watch
Detail price for champion C6561 watchs - Champion Sportline Solo 900 Heart Rate Monitor Watch
How much is a c9 cr2016 watch worth?
http://price.salespider.com/cpidt2-b76ab6bb1fa02d11c385a54782005b49/mens-c9-by-champion-analog-digital-watch-blackorange
Aug 06, 2015 | Watches
How do you "unfreeze" a champion c9 wrist watch?
I am having the same problem. The battery is fine, the seconds are ticking away, but none of the side buttons work. The light doesn't come on and nothing happens with any of the others either. The only thing that did work was pressing all four of the buttons simultaneously, which seemed to totally reset the watch. The problem is it reset but didn't fix the buttons. So now I can't even see the correct time anymore.
Nov 21, 2014 | Geneva Watch Group C9 by Champion Mens...
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
I have a champion irrigation valve. with current on solenoid hums...valve doesn't open...square metal bracket holds round ceramic? solenoid...slides up and off stem of valve Will this replacement...
If the solenoid hums, it MAY not be the solenoid. Inside the valve is a rubber diaphragm that must move when the solenoid opens. I would remove the solenoid, make sure the plunger is inside and, while retaining the plunger, apply power. If the plunger is pulled into the solenoid, it is probably not the solenoid. MOST solenoids have the same threads but all do not and you must get the same dimensions.
Most valves have repair kits that allow you to replace the diaphragm & a few other minor internal parts.
Good Luck,
Gary
Sep 14, 2011 | Champion International Champion Irrigation...
How do you turn on the heart rate monitor on a sportline heart rate watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Apr 19, 2010 | Sportline C9 by Champion Fitness 910 Watch
I have a Champion Sports Referee Watch. I need to
Get to the alarm screen by pressing the mode button as many times as you need to. At the alarm screen, a short press on the lap-reset button toggles the chime on and off. Don't press and hold the lap-reset button: that toggles between alarm 1 and alarm 2.
Mar 16, 2010 | Champion Watches
Champion Sportline Solo 900 Heart Rate Monitor Watch Logo
24 people viewed this question
Top Champion Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Champion Watch Expert? Answer questions, earn points and help others
