Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konica minolta bizhub 164 error code c6101 - Konica Minolta bizhub C250 All-In-One Laser Printer
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
firecontrol7
  • 6161 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
SOURCE: Error code C-0211 Konica Minolta Bizhub C-351
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
Posted on Nov 03, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
We have Konica Minolta bizhub 164 copier machine its showing c6101 error code how to resolve that error plz tel me
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
Sep 15, 2015 | Konica Minolta Office Equipment & Supplies
How can i fix error C6101 of my BH-195?
Hi
The problem appears to be with the scanner unit
Scanner home detection failure
- When the power switch is turned ON or a scan operation is completed, detecting the home position fails. 1 Turn OFF and ON the power switch.
4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB. You can find the page here, and it gives other error codes and their solutions as well.
Error Codes Konica Minolta bizhub 195 page 2
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Konica Minolta Office Equipment & Supplies
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
replace the drum and developer and then reset the counter
How to solve error code C2351 in konica minolta bizhub 164
On a bizhub 165 it's a fault with the sucktion fan motor so check
to see if turning and replace if needed. If this does not fix print control board might need replacing.
Jul 03, 2014 | Minolta bizhub 200 All-In-One Printer
Bizhub 164 error code CC153
Have a tech come and re-flash the firmware, and check the NVRAM. Firmware is only available fro secure Konica Minolta Web site they like to keep they software secure. You mite also have a bad control board. Or the memory on the board, a Tech is required.
May 08, 2014 | Konica Minolta bizhub Office Equipment &...
C6101 error code in konica minolta 164
scanner home position. The scanner located under the big glass to the left is not finding home check that it is not located or jammed.
Jan 30, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code c2558 in konica Minolta bizhub 164
help me my konico minolta bizhub 184/164 error (C2558) my mail id ganaa_et24@yahoo.com
Sep 30, 2013 | Office Equipment & Supplies
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
