Question about Bosch Washing Machines
Code f80 bosch logixx8.
The machine peeped several times during a wash cycle then stopped. F80 was in the display. Switched machine off for 30 minutes. Afterwards it switched on for a short while but after attempting to restart a wash cycle, it went dead. i.e. nothing works and nothing showing on the display
SOURCE: Fisher and Paykel error codes
Think you have the same problem I had ! I changed the water pump and cured the problem. Hope this helps !
Posted on Apr 12, 2009
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
richroth
  • 9472 Answers
SOURCE: bosch classixx 6 1400 machine
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Posted on Nov 27, 2010
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Bosch Logixx8 not working.
try turning the plug off for 5 minutes, if that fails hold the power button in for 30 seconds
Jun 30, 2012 | Washing Machines
My multiPass F80 alarm is flashing a check printer press resume key code and I not able to clear it this happened after I stopped it in the middle of a fax mode
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Dec 02, 2010 | Canon MultiPASS F80 All-In-One InkJet...
I have a bosch logixx 8 washing machine. Fault code f67 when I turn the machine on. What does this mean?
I have Logixx8 WAS 32782 that got the f-67 code. I had it repaired today and the technichan updated the software. f-67 was indicating "lost contact with display panel". The display panel had of some reason erased its software. SW update was the standard solution.
Oct 02, 2010 | Bosch Washing Machines
I have a half way through film in my Nikon F80 and I have changed the batteries. At first it wouldn't go on, there would be the error sign blinking after turning it on. I turned it on and off several times...
You can force your camera to rewind, but you will have a partially shot roll of film. If you continue to shoot your counter will be off but when the film cannot advance any more the camera will rewind.
Jul 27, 2010 | Nikon F80 35mm Film Camera
Canon Multipass F80 printer. "Check printer press resume key"
On the f80 you need a shop to go to service mode and get the error code and tell you what the problem is. Could be purge assembly, waste ink full, feeder error, printhead error, any number of possible problems.
Aug 05, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canon Multipass F80 color cartridges **** up other colors
hello please try this
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Water remains in fabric softner compartment
Is the softener entering the machine; that is at the appropriate time? You can take a peep at this time, if possible. If it is water it is okay; this is just the remaining water. The softener is dissolved with water and flushed into the machine.
Dec 05, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
