Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website; www.adbdriver.com/downloads/ or click on link below for direct download. ADB Driver Installer (9.22 MB) next, install the ADB driver then you will see a USB root on notification area on your PC.
next, download the fastboot click on link below; https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
next, command prompt will open and you need to type these commands;
This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
no command could be either software or hardware problem. if your flash memory has not gone then you can try a factory restore. you did not mention which tablet you have so if its apple then plug it into itunes,if its android then turn the tablet off. press and hold the volume up button and the home button together and keep holding them while you turn the tablet on ,only release them when you see the green android man. now you should be presented with a secret menu,scroll down to factory restore and reset the tablet. hope this helps
Pull battery. or
search for cmd.com
execute cmd.com
type in " shutdown /s " to shutdown the computer at command prompt
type in " shutdown /r " to reboot the computer at command prompt
You need to do a factory reset by holding down the power and the volume (-) down button at the same time until u see a black screen with Command prompts.. After this use the volume up and down buttons to stroll up and down and the power button to select.. Go down to data factory reset and press select then select yes.. And your tablet should reset itself.. This May or may not work on the first try.. Please wait at lease 5 minutes for it to boot up because it will take a while to boot after this so don't get all frustrated. If it's still stuck at the go logo just go back to step 1 and repeat.. This is what I did for my tmax 9 tablet when it was stuck at the go logo.. It didn't work the first ten for me but for the 2nd factory wipe it did the trick..
You can't format a computer from the command prompt. the only way to format a hard drive is to get the disk for the operating system. put the disk in the computer then restart the computer. when the computer is starting up at the bottom of the screen will be some commands, one of the commands will to boot from disk. select this option. they the computer will take you through a bunch of screens asking whether or not you want to do this because formatting your hard drive will erase everything on your computer. once you say yes to all these screens you computer will start formatting.
I hope this information was helpful, if you have any comments or questions reply to this post and i will help as much as possible
