Can you please help me with a 4 digit code for denon DCD-480 compact disc player
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
0051,0049,0044,0042. Try these codes. For more information http://electrohelponline.blogspot.com/
Posted on Nov 23, 2013
I have a dcd 1650 and it won't read discs, but sometimes it does, I have checked and cleaned lens
A Laser Lens malfunction will cause this to happen and is a common problem. This can be fixed at home if a new Laser Lens or Laser Lens w/ transport can be found for your unit. I used ebay to purchase a new Laser Lens for my Denon DVD 5900. The part is also sometimes available from parts stores like Parts Express for a premium, $100+ Parts Express vs $17 ebay in my case. I would recommend purchasing a FACTORY SERVICE MANUAL from an online vendor. The manual will cost between $10 - $20 and is downloadable. The installation is very straight forward. The part that might not be clear would be the grounding shorts on the new Laser Lens. THE NEW LENS COMES SHORTED AND AFTER THE PART IS INSTALLED IN THE PLAYER THE GROUND SHORTS MUST BE UNSOLDERD FOR IT TO WORK CORECTLY. The part comes this way to protect the Laser from static shock damage.
The repair on a Denon DVD 5900 cost $30 and took about an hour to complete.
Jan 07, 2013 | Denon DCD-1650 CD Player
I want the correct valves for C-105 and R-100 , R-103 for my denon cd player dcd-f100.
Dear lovin4sha,
The correct valves for the specified components are :
C-105 ------- 22 mfd 100 v
R-103 ------- 3.3 K 1/5 watt
Enjoy bye.
Jun 04, 2011 | Denon DVD-F100 DVD Player
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
Feb 01, 2009 | Audio Players & Recorders
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
