Question about LG Computers & Internet
Beeping roboking When on charge it beeps continually
thehumble1
  • 137 Answers
SOURCE: beeping before booting
probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Posted on Nov 19, 2008
SOURCE: Continual beeping
I've had this problem a couple of times.. I filled a pan of water, poured it into the bottom, turned it on and made sure the pump was actually pumping.
I then unscrewed the dishwasher from the housing and turned off the water and electric, removed the outlet and gently rocked the dishwasher to try and dislodge anything inside the pipes.
Worked twice now anyway!
Hope this helps :)
Posted on Apr 26, 2009
  • 3 Answers
SOURCE: beeping while charging.
one the top left where you turn down your speaker volume when off the phone turn that all the way down but it will also turn down your ringtone if im right
Posted on Apr 30, 2009
sipu
  • 51 Answers
SOURCE: My LG Xenon started beeping at me after it
just press the reset all and see
Posted on Mar 30, 2010
SOURCE: continuous beeping and display "error
what's the answer
Posted on Mar 20, 2011
I am charging my scooter and it is beeping what do i do
Charge without the key on. Make sure your charger is applying power to the scooter. It may have a blown fuse or some other internal problem. If your batteries were totally discharged your charger will not recharge them. You'll have to charge them individually with an automotive style battery charger that is NOT an automatic charger. It may take 3 days continuous charging to recover enough charge before your scooter charger will continue to charge until the batteries are fully charged. If this doesn't work then the batteries will never take a charge nad need to be replaced.
Oct 15, 2014 | Health & Beauty
Continuous beeping
You have a faulty key on the keyboard. Replace the keyboard, they are not expensive. Look at ebay for prices.
Feb 06, 2014 | Computers & Internet
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
Continues beeping
did you leave it plugged in to let it charge? ups's will beep continuosly till they are charged, if it has dead battery packs inside, it will continue to beep because there is no battery charge to support its job. leave it plugged in for 2 hours. if it doesnot stop beeping, toss it and get a new ups
Jun 04, 2010 | CyberPower 575SL (CPS575SL) UPS System
Ive got a smart UPS 4 2 0 APC and i dont know what the beeps mean?
It depends upon the beep. When it is a long beep, it means that the battery is running out. You need to charge it first before using.
When you hear beeps but not a continuous one, it indicates that the UPS is charging and it should automatically stop.
Sep 27, 2009 | Computers & Internet
My unit started beeping continually, I changed batteries, but
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Aug 29, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
