Question about Genius MousePen 8x6 (MOUSEPEN8X6)
Pen pressure tried everithig!!!
  • Eva Del Villar
    Eva Del Villar Nov 23, 2013
    ok, sorry i din't know i was posting a question!! i'm new to this, i have a genius mousepen 6x8 and it doesn't work with pen pressure on cs6, i need help!, also my preset brushes seem to have a bug, i'm missing some...any tips?? here's a picture.
Touch sensitivity not working in my pen.
Reasons Why PEN PRESSURE Isn't Working (Viewer ...
? 4:04
https://www.youtube.com/watch?v=lHPRyDgGErY
Feb 1, 2015 - Uploaded by Aaron Rutten
I recently got a new tablet because my old one was broken. ....you find that you have lost pen tablet pressure sensitivity this will fix the problem: ...
pressure sensitivity of Wacom tablet not working anymore - Adobe ...
https://forums.adobe.com/thread/1152988?tstart=0
Adobe Systems
Oct 9, 2015 - 40 posts - ‎26 authors
I have no idea why, but the pressure sensitivity of my tablet won't work anymore. ...The tablet and pen are working within Windows. ..... Control Panel >Pen and Touch > Press and Hold then disabled the check-box Enable ... Wacom pen pressure issue, possible solution. ' Adobe ...
Dec 17, 2015
tablet + pen pressure + illustrator CS5 issue ' Adobe ...
Nov 27, 2015
Bamboo Pen Pressure not working in Illustrator ...
Feb 6, 2013
More results from forums.adobe.com
Why isn't my pen pressure sensitivity working? ' Wacom
Jan 19, 2016 | Genius Computers & Internet
Why won't my wacom grip pen click when it touches the tablet instead of hovering and selecting text?
Have you tried pulling the nib out (the end bit you draw with)? It could be that something is sticking the nib further inside the pen than it should, which is telling the pen you are applying pressure. As far as I know there is a little spring inside the pen that the nib pushes on when you touch the pen to the tablet. Perhaps the spring is permanently squished in.
May 26, 2014 | Wacom Intuos3 Grip Pen
Wacom Pen Pressure issues
Try hitting the pen head into your hand 5 times. Do the same with the eraser ( do it pretty hard but not too hard. I hurt my hand with the pen tip a LITTLE so you can gauge it by that). The humidity in the air causes the pen pressure to stick apparently. I had the same problem and this made it work. You should try and clean it too but if you don't want to take the pen apart this is the way to go. i hope this helps.
Mar 28, 2010 | Wacom (PTZ930AC) Graphic Tablet
My Bamboo tablet will not respond to pressure when I use it. I am primarily using Photoshop CS3 for drawing... I've reinstalled all of the drivers, and updated them, but it will still not give any...
Mar 19, 2010 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Photoshop cs4 pen pressure not working. Windows xp. Have the latest photoshop update and Wacom tablet update. running Cintiq. Have tried reinstalling tablet and photoshop...did not fix issue. ...
In photoshop, press F5 to bring up your brush control window. Under shape dynamics and other dynamics and any other brush attributes you wish to control with your pen, make sure that control is set to "pen pressure" in the drop down menu. Hope that fixes it for ya.
Dec 16, 2009 | Genius G-PEN F350 Ultra slim tablet....
Software and or Photoshop problems - no pressure sensitivity
In photoshop, press F5 to bring up your brush control window. Under shape dynamics and other dynamics and any other brush attributes you wish to control with your pen, make sure that control is set to "pen pressure" in the drop down menu2_bing.gif. Hope that fixes it for ya
Aug 17, 2009 | Genius G-PEN F350 Ultra slim tablet....
Pressure-sensitivity with pen doesn't always work
i'm assuming you clicked on shape dynamics...
use your pen to open photoshop with, worked for me...
Jul 14, 2009 | Wacom Graphire4 4x5
No one knows how to turn on pen pressure for photoshop 7
If you haven't tried this yet:
First go to "Windows" on the task-bar of Photoshop.
Go down and select Brushes.
A window should pop up with several different setting for your brush. Check the Shape Dynamics if it isn't checked.
And then the pen pressure should work I believe. Hope I helped.
Apr 11, 2009 | Genius G-Pen F610 (31100050100)
Pressure sensitivity problem in Photoshop CS3
Before you start Photoshop press and hold the shift key and wait until photoshop has loaded.
This should take care of the problem.
Feb 11, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Pen no longer pressure senstive in painter
Go to Start>Programs>Wacom>Wacom Properties and in there you should be able to "Add" Painter X to the programs recognised by the tablet app.
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 15, 2009 | Wacom Intuos3 Graphic Tablet
Genius MousePen 8x6 (MOUSEPEN8X6) Logo
52 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Mirca Sekosan
Mirca Sekosan
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
