Question about Memorex MLT2022 20 in. EDTV-Ready LCD Television
No picture and no sound
I have a 20 inch memorex and there is no picture and no sound, Im not sure if something went and if so what part do I need?
  • betterlkn031 Nov 07, 2007
    I have no picture or sound the red light will go on but thats it. What wrong, did something go?
I have the same TV. and same problem. I changed the power supply with a similar one that has the same plug. the TV came back to life. voila.
Posted on Oct 14, 2007
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
The picture goes blank after I turn on the power. stays on for about less then a minute but the sound is fine. this a small 19 0r 20 inch screen lcd tv by memorex
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
I hope this will hear to solve the problem....
Jun 27, 2011 | Memorex MLT3221 32 in. LCD TV
Memorex mvd2047 dvd player - no audio when playing dvd
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Jul 23, 2010 | Memorex MVD2047 DVD Player
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
Wiper arm goes off of the windshield when it is raining
Sounds like you just nee to remove them and reinstall them in the correct position. Take them off, run the wipers for one cycle until they park. Install the arms so the blade is about an inch above the bottom of the windshield.
May 02, 2009 | 1995 Honda Accord
No picture but has sound
hey twinbrother, sounds like we have the exact same issue, i'll let you know if i figure anything out. sure seems like it blew a fuse or something?
Mar 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Memorex HDTV no picture
I am going to assume that you have not already found the answer to this problem. It is actually pretty common for flat panel televisions in the winter to be too cold to turn on. What I did when faced with this problem on my 32 inch memorex was turn it on for 30 minutes while covered with a fleece blanket, than turn it off. When you turn it back on it should work...did for me!
Dec 31, 2008 | Memorex MLTD2622 26 in. LCD TV
19 inch portable TV Memorex
Hi! I realize that you posed a couple years ago, but I am having the same problem with my relatively new Memorex MLT 3221 model. How did you solve it??? I have tried every 'layman' solution that I can think of! Please help!
Dec 31, 2006 | Memorex MLT2022 20 in. EDTV-Ready LCD...
Memorex tv
There is a capacitor going bad and is not charging all the wayor it takes a while to charge,is an electrolitic cap so it has polarity and the replacement needs to be conected the same way,the circuit board has the marking were the negative and the positive are and the cap is marked too,he should be a 1.5 microfarad at about 160 volts and sometimes is close to the vertical Ic,if you are familiar with tv service this information should help but if you are not too familiar seek the help of a servicer,it should not be too expensive,the vertical IC might need to be resoldered.Let Us know if you need more help.
Oct 10, 2006 | Memorex MT2206 TV
Memorex MLT2022 20 in. EDTV-Ready LCD Television Logo
113 people viewed this question
Top Memorex Televison & Video Experts
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
