Question about SanDisk Electronics - Others
Olkya Volume fix Memory - SanDisk Electronics - Others
Tip
How to fix Volume issues in PSP Portable
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
on Feb 13, 2010 | Video Game Consoles & Games
Volume controll is going nuts.
Hi Manuel
I suppose the problem of your unit is memory, sometimes this problem can be fix by applying service mode, but if not, then memory should be replace and I would advise you to send your unit to service center.
Jan 16, 2014 | Televison & Video
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
My samsung Galaxy 1900 keeps poering down and I have to remove the battery to start it up again
I think the problem is on your operation system, the wrong application or bad application cause it happens, to fix your problem you need to do reset to factory setting. To do a reset to factory setting you must save all your data which located in your phone memory because this way will erase all information on your phone memory then turn off your phone. After you turn off your phone press a volume down key and press and release a power button, then your screen will displayed some options such as: Fast Boot, Recovery, Clear storage and Sim Lock. Select clear storage option by using the volume up/down button to scroll to the option then click and release the power button again, then confirming your selection by press volume up for yes and volume down for no.
May 21, 2011 | Samsung Galaxy S GTI9000 Smartphone
My volume dont work is there anyway i can troubleshoot it or restart the whole thing?
Feb 13, 2010 | Sony PlayStation Portable (PSP) Console
When i turn my car on my cd player is full blast i cant find where to fix it
I want to know if you still can volume it down. If don't then your volume button sw for down was damaged.If still can, your cd player's memory is not functioning. Check the wiring of batt. memory back-up wire from the player, this must be connected to unswitch power supply. ( the power supply is always "ON")
May 10, 2009 | Car Audio & Video
Would like help with what the optimal gaming settings are
Got free help somewhere else and problem solved
Nov 11, 2008 | Computers & Internet
Audi concert sound system volume control faulty
problem is due to the microprocessor that runs the whole show, or more precisly a part of it that
remembers the volume level you had set when you removed the key, this memory is call EEPROM,
(electrically erasable programable read only ymemor), it can remember its data without power being applied,
this type of memory had a limited number of write cycles( number of times it can be re -written lets say between 20-50,000)
the early concert radios would only write to this memory when the radio was switched off, so that equates to 2-3 times a day in normal use, later radios have a software bug that writes(updates) this memory EVERY time you alter the volume level, you will quickly use up the 50,000 write cycles and the memory becomes defective, the symptoms are full volume that cannot be controlled, and it will be temperature sensitive often improving when it warms up.
Shame on you AUDI, this product was defective from manufacture but you dont honour any player out of warrenty, EEPROM has limited write cycles any engineer knows this, your software is defective.
the fix is to replace the microprocessor that has 1. new EEPROM onboard & 2. new software that doesnt weat it out!...the bad news is this fix is way more that the cost of a used radio off EBAY
Jul 27, 2008 | Audio Players & Recorders
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Electronics - Others Logo
62 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
