Question about Brother LS 2160 Sewing Machine
Lower feed dog
How do I lower the feed dogs on Brother LS-2160?
SOURCE: Feed Dog on Brother 270d stuck in up position
I finally figured this out. The feed dog switch in the back was not hitting anything when I moved it back and forth. There is a screw on the underside of the machine that I tightened. It seemed to do the trick. Thanks.
Posted on Jan 15, 2009
talk2ginny
  • 34 Answers
SOURCE: Feed dogs dropped on brother pq1500s, won't come back up
Welcome to FixYa! You can purchase a manual for the PQ1500 from this site:
https://www.sew4less.com/product/4255/Brother_PQ1500_Instruction_Manual
If you have a minute, please rate my answer honestly so I know whether I understood your question and provided helpful information. Thanks so much, and good luck. Feel free to comment if you have other questions, or if you'd like me to search for other links.
Posted on Feb 05, 2009
bargainbox
  • 1388 Answers
SOURCE: Brother Super Galaxie 2100 - Feed dogs will not lift
Remove needleplate and clean out the built up lint between the teeth of the feeddogs.
When moveng from Feed Down to Up, rotate handwheel one revolution to re-engage.
If neither is a problem and your manual is of no assistance, take it to a service centre to check it out and quote.
Posted on Aug 19, 2009
  • 1788 Answers
SOURCE: how do I adjust the feed dogs on the brother
Do you have the darning plate over your feed dogs? Read your manual, to see what the problem is. If, you do not have a manual go to www.brother-usa.com under support and download your manual for free, when you enter your model number-LS2125
Posted on Sep 16, 2010
  • 1788 Answers
SOURCE: feed dogs are dropped How do i raise them? Ls
Do you have your darning plate on? If so, remove it. Read your manual and you will see on page 38. If, you do not have a manual go to brother-usa.com and download a manual for free.
Posted on Sep 17, 2010
How do I lower my feed dogs on my Brother XL3200 sewing machine?
The Brother XL3200 does not have an option to lower the feed dogs. It came with a darning plate, part number XA3443151, to cover the feed dogs. This is available at Amazon.com for less than $10, including shipping. See https://www.amazon.com/Brother-Darning-Plate-XA3443151/dp/B002EZVSUU . It's also in stock here: https://www.sewingmachinesplus.com/pd60-XA3443151.php .
The manual for the similar Brother machines, XL2600 and XL3500, show using the darning plate on page 38. This manual is available here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_2600_2610_3500_3510_EN_206.PDF .
I hope this helps.
Sep 21, 2017 | Brother Sewing Machines
How do I raise the feed dogs in a Brother LS2125 sewing machine as they seem to be lowered?
Perhaps you will find the answer here:
LS 2125 2125i 2129 United States Brother Solutions Center
FWIW, the manual indicates that your feed dogs do not lower. Instead, you are provided with an accessory that covers the feed dogs when you wish to use the machine without feed dogs.
Jan 15, 2017 | Brother LS-2125 Mechanical Sewing Machine
How do I lower the feed dogs on this machine
Joyce, Some machines do not have adjustable feed dogs. Do a Google search your make and model# manual or how to lower feed dogs. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do raise or lower the feed dogs Brother
Tutorial Adjusting Feed Dog Height and Position ABC Sewing Machine
What Are Sewing Machine Feed Dogs and How Do they Work
Aug 23, 2016 | Sewing Machines
How do I lower the feed dog on a Brother LX3125?
Look on the back of the machine near the feed dogs for a lever to lower them.
If there is none then you need a feed dog cover (or darning plate) that goes over the needle plate.
good luck!
Feb 23, 2015 | Brother LX3125 Sewing Machine
Can you tell me how to lower the feed dogs on my Brother XR-52 for free motion sewing?
You use your feed dog cover, it is a plastic cover you put over your feed dogs. Your manual will show you, if you do not have your manual go to www.brother-usa.com and select support, home sewing & embroidery group, then select your manual, you can then download your manual for free
Apr 23, 2011 | Brother XL-5130 Mechanical Sewing Machine
How do I adjust the feed dogs on the brother LS-2125?
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Feed dog wont feed the fabric
Remove the needleplate and clean between the teeth of the feeddogs.
Ensure the feeddogs are not lowered for free motion sewing.
Don't know the make/model to be any more specific, so post back here or to the Contact Us page at  www.bargainbox.com.au if there is more to do.
Nov 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Feb 26, 2007 | Brother LS-2125 Mechanical Sewing Machine
Brother LS 2160 Sewing Machine Logo
22 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
