Question about Dishwashers
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
Electrolux Dishlex Dishwasher DX 302
  • 40 Answers
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Posted on Dec 30, 2013
4 Suggested Answers
SOURCE: Dishwasher Dishlex DX302WB No Hot Water
Thank you This worked for me!
The heater was ok found dry joint on pc board
see attatched photo
Took top 6 screws out of door holding front panel in place
Removed front switch panel
I then labeled the 6 cables with 6 being for the heater
Removed pc board from housing to find dry joint
using small piece of wire and solder repaired board
re assembled
now as good as new
Posted on Jun 14, 2008
  • 159 Answers
SOURCE: The dishwasher (Dishlex DX302) is not drying the
Have you selected the eco wash cycle.it wont dry on an eco cycle.
Posted on Jun 04, 2010
SOURCE: user manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Posted on Oct 29, 2011
Dishlex 302 leaks from underneath
Good Morning Friend,
This appears to be a UK Electrolux dishwasher; however, if you have a US Electrolux model, here are a few tips you can attempt to troubleshoot the issue: First, Use only fresh detergent designed for automatic dishwashers. Measure detergent carefully. Possibly try a different brand of detergent. Secondly, spilled rinse aid can cause foam and lead to overflowing. Wipe up any spills with a damp cloth. Lastly, check to see if your dishwasher is level. If your dishwasher is still leaking, after trying the above solutions, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best regards-
WP
May 19, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
I have a Electrolux Dishlex DX302 and the last few washes I have notice that on the ususal cycle it is not heating (steaming) at the end. The dishes are still coming out half clean. I am not sure why the...
Doubble check the settings on your machine.
It is a long way from my heater to the washer. Hot water is essential to the operation of any model machine. I always get hot water to the sink (by running the hot water, of course) before I start the washer. I can tell when I fail to do this.
Just a thought, I hope this aids your situation.
Of course your washer heater may have failed ... You can check it using a volt/ohm meter.
Thanks for your question this morning @ FixYa.com
Jul 12, 2011 | Electrolux Dishwashers
What does the error code 50 relate to for our electrolux dishlex DX302 dishwasher?
Thanks for this information. I was able to follow triburi's instruction and just make sure all the electrical connector is connect properly. It works after i put it all back. I guess i am just lucky one of the connection come lose.
Jun 19, 2011 | Electrolux Dishwashers
Hi I have a Dishlex DX302. After an intense wash it leaves a film of scum / powder on the dishes and sometimes does not wash properly. I have tried using various soaps and also tried to use a dishwasher...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
No drying cycle on the electrolux dishlex 302 any idea's
Check your heating element..
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Elextrolux dishlex DX 302 - not cleaning dishes properly and dishes still wet after drying
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 12, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Dishwashers Logo
447 people viewed this question
Top Dishwashers Experts
Owen Barnes
