Turn off hotel mode
How can i switch off the hotel mode?
  • Televison & ... Master
  • 9,742 Answers
You need the service remote for that. Try the tv manufacturers web site to see if there is a work around.
Posted on Jan 13, 2014
  • Carol Smith Sep 06, 2015
    We had to order an original remote for our model t.v. They said that would work.
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
How to get Sanyo dp50741 out of hotel mode?!
This is for Panasonic but might help you
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the AV/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above.
Read more: My 50" sanyo plasma tv is stuck in hotel mode how do i get it out of hotel mode? - When i turn the tv on it says D01--32 and a blue lower case u under it :: Ask Me Fast at http://www.askmefast.com/My_50_sanyo_plasma_tv_is_stuck_in_hotel_mode_how_do_i_get_it_out_of_hotel_mode-qna4904417.html#q5129429
Nov 28, 2015 | Sanyo Televison & Video
LED Hotel Mode key?
You have to enter its service mode option to turn ON of OFF and Adjust the Hotel mode options. If you wish to get more details about how to enter hotel mode, and make necessary adjustments, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timslide option. Never forget to EXIT service mode, after you've done all necessary adjustments.
Jun 28, 2013 | Televison & Video
Samsung plano cs-15k5ml
To make it out hotel mode, you have to enter its service mode. http://electronicshelponline.blogspot.com/ Check this link. It has service mode to many brands TVs, including Samsung. Pull up older posts by it sidebar.
Jun 05, 2013 | Televison & Video
Sanyo tv in hotel mode
Possible only with buttons on some models to do this---usually the hotel remote is needed for this function for clear reasons--they did not want people to switch the set to this in the hotel.
Oct 29, 2012 | Sanyo Televison & Video
Geedmorning, please help me to unlook FROM HOTEL MODE of old tv color 14" THOMSON 418x ITC008 EU. Many thanks best regards
To exit the hotel mode you have to put your tv on stand by using your remote. Then you have to switch the tv off using the power button on the tv. After that, while pressing the teletext key on the remote (magenta one), switch the tv on using the power button on the tv. Select "LOCK" and turn it off.
Hope this helps!
Apr 28, 2011 | Initial 26 in. LCD TV
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
IT'S STUCK ON HOTEL MODE-Bose system
I followed the instructions that are posted on your web site again. The trick was to hold the enter key in, turn the on/off switch at the same time. Continue holding the enter key in, turn the on/off back on, hold for two seconds and then hit the volume down. It worked.
Thanks Marion
Jan 29, 2009 | Bose 3·2·1 II System
Stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Jan 16, 2009 | Philips RC2573 Remote Control
Can't find menu on hotel tv
YOU WILL NEED THE SPECIAL REMOTE TO DO THIS. AND I THINK SOME OF THEM HAVE ABILITY IN SERVICE MENU TO TURN OFF HOTEL MODE. OR YOU CAN TRY USING ANY PHILLIPS/MAGNAVOX REMOTE WITH THE STATUS BUTTON AND TRY THIS.
PRESS MENU-9-6-5-2-STATUS AND YOU SHOULD BE IN THE SERVICE MODE TURN OFF THE HOTEL MODE
Jan 03, 2009 | Mitsubishi CS-35707 35" TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
