Question about Roomba Vacuums
Roomba error 5
My roomba('s) show Err5 and one of them the brushes don't spin anymore. What could be the problem?
  • Roomba Master
  • 18,424 Answers
4 Suggested Answers
SOURCE: Roomba Discovery
I read somewhere that you need to clear the software in case there is a glitch. To do this, take the battery out and then, simultaneously hold down the "spot" and "clean" buttons for 30 seconds. Replace battery. This has worked for my Discovery model.
Posted on Oct 10, 2008
SOURCE: Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Posted on Nov 20, 2008
SOURCE: runs for awhile then says error 2 please remove
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Posted on Jan 08, 2010
I have a Roomba a 531 on its underside. It is stopping every 5 to 6 minutes and stating that the brushes need to be cleaned. I lift it 2 inches place it back on the floor and it's good for 5/6 more.
Sounds like it takes 5/6 minutes to detect the problem. Remove the spinning brush and insure it's not clogged underneath. Also check the ends of the pair of long, soft brushes (flexible tubes) as they often fill with stuff.
Aug 21, 2017 | Roomba Vacuums
Why isn't the side brush spinning anymore?
It sounds like you need to get a new brush motor. They are modular and easy to replace.
May 05, 2014 | Roomba 780 Robotic Vacuum
Roomba err5
please go to the page and see the video, instruc, manual , maintenance, tip, and fix it your problem easy.
http://homesupport.irobot.com/app/home
God bless you
Sep 22, 2012 | iRobot Roomba 550 Vacuum
The side brush on my Roomba will not spin. I just got it April 16th 2010
unscrew the brush see if hair ect. is wrapped around.if not may need a new motor
May 20, 2010 | Roomba Robotic Floor Bagless Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
153 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
