Question about bryton Rider 20 E GPS Cycle Computer | Cycle Computers
How do you set the bryton rider 20 to show distance in miles
Ineed to logout Bryton McClinton email to login michellehicks email how do I do that
Bryton needs to log out of his email account. Then Michelle needs to login.
Feb 04, 2017 | Computers & Internet
Tip
Susspension set up for Motorcross bikes
When I need to set up a motorcross bikes suspension I set all the settings (both rebound & compression) to the middle of the range on both the front suspension & the rear suspension
Now, measure the distance from the inside of the rear mudguard and the top of the rear tyre & note the distance.
Now repeat with the rider seated in position and note the difference,
This value should be 20mm. If not adjust rear spring pre-load to correct.
Now, measure the distance from the inside of the front mudguard and the top of the front tyre & note the distance.
This value should be 15mm. If not adjust front spring pre-load to correct.(if adjustable).
This gives you your starting point for the fine tuning with the dampening adjustments to suit the riders preferances.
Regards Andrew Porrelli
on Dec 05, 2009 | Motorcycles
Bryton rider 20
This has to be at the sensors. Adjust them closer until you get a reading. May need spacers to get closer.
Apr 13, 2014 | bryton Rider 20 E GPS Cycle Computer |...
Reset odometer rider 20 bryton
The device recovery tool downloadable from the Bryton website will fully reset the device including Odometer
Jan 03, 2014 | bryton Rider 20 E GPS Cycle Computer |...
How do I reset the distance to empty
The DTE is automatic and is the result of your previous miles per gallon multiplied by the gallons of gas registered in your tank.
Unlike the Trip miles, this DTE number can not be reset. It will vary by the fuel mileage per gallon recorded at each startup. That is why if you filled the tank and showed 400DTE you may have had 20 Gallons multiplied by 20 MPG. But if your new average is 16 MPG then it would show 320 DTE.
Mar 05, 2013 | Lincoln LS Cars & Trucks
The distance for the trip in my favorite is wrong.
Sounds like you might have "off road" selected for your navigation preference. Shortest distance between 2 points is a straight line, or great circle for GPS units. As the crow flies will be shorter than a road route.
Jul 04, 2010 | Garmin nuvi 205W GPS Receiver
Incorrect distance tracked on Garmin Forerunner 405
Could it be that the Unit for distance is set to statute and so displaying miles instead of K?
May 31, 2009 | Garmin Forerunner 405 010-00658-20
Loud nosie coming from rear left drum
sounds like it may be a wheel bearing
Apr 21, 2009 | 2005 Jeep Wrangler
bryton Rider 20 E GPS Cycle Computer | Cycle Computers Logo
63 people viewed this question
Top bryton Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a bryton Cycling Expert? Answer questions, earn points and help others
