Question about Electrical Supplies
Scorpion sdi 1000 generator carburetor adjusting
When generator is running it,s fine then starts to run as if starved of fuel...spark plug fouls up once cleand runs for a while then stops again...have stripped machine and may have upset setting on carburetor
SOURCE: generator runs for a short time
does your generator have a metel tank? If it does it probley has rust in the shut off valve under the tank.
Posted on Nov 30, 2008
SOURCE: Coleman Powermate 6250 only runs with choke closed/air restricted
A call to Elliott Small Engine solved my problem - Oil Guard. I had checked the oil and it was just a little low but seemed well within the normal range. I was told to add more, bringing it just over the Full mark. It seems that the low oil protection system is very sensitive and shuts down the engine even when the oil is withing 1/8" of the mark. I added about 2-3 oz of oil and no more problems
Posted on Dec 16, 2008
SOURCE: Honda E-1500 Generator misfiring after less than 10 minutes.
hi, i have a portable generator that has Nissan GX 1600 on it,who makes it? and do they have a web site?
Posted on Aug 29, 2009
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
witserv
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
Hard to start ,and foul the plugs every 1000 miles .
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery nearly discharged, should have 12.5 volts.
4. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.*
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.*
10. Enricher valve inoperative.*
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
* Carbureted models.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Honda Rebel Hard Starting and bad Iddling
Troubleshooting No Start Honda Motorcycle
How To Get Your Motorcycle Up Running Randys Cycle Service
Dec 12, 2015 | Motorcycles
Polaris 600 cuts out at hi rpm
Check your Air Filter, clean it out, check for obvious blockages. Change the filter if it looks well used (look for excessive dust or color change on the inner part of the filter) or obvious wear.
Check for other blockages around the air filter inlet.
Check the spark plug, just change it for a new one so that eliminates that possibly.
Check your fuel filter and replace if needed.
Check the fuel tank for corrosion or dirt in the fuel. Empty it out, Clean it and add new fuel, be sure you have the correct fuel.
Check your Air / Fuel mix adjustment screws on the carburetor.
Hope that helps a bit
Good Luck
Feb 10, 2014 | Winter Sports
2005 Yamaha FZS 1000 Fazer hard to start
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Info needed on running lean rich
Yamaha Fazer 1000 Starting problem
Yamaha FZS1000N Service Manual
OEM parts for Yamaha
YAMAHA FZS1000 Owner Manual
Sep 03, 2013 | 2005 Yamaha FZS 1000 Fazer
I have a portable generator that did all the fuel clean out and sprk plug change stuff, and it finally started but wouldnt remain running. I had the air filter off and by accident, with a rag in my hand,...
No The rag is just letting you know that your carburetor is starved for fuel. It may need adjustments on the carburetor if you can get to the adjustment screw,check your fuel filter and the gaskets it may be sucking in too much air and not enough fuel.
Aug 03, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a Honda EG5000x that has been sitting in my garage for the past 10 years. I changed the gas and oil, it started up with about 5 pulls and seemed to run just fine until I plugged my compressor in. It...
Is there a spark? If yes, then the fuel supply is blocked, either in the tank, hose, or carburetor. Enough fuel gets by to run a small load, but a bigger load starves it of fuel. The empty carb bowl makes it hard to start until enough fuel gets into the bowl. Clean the whole fuel system and all should be well. Try turning in all the carb adjustment screws then backing them off to their original positions, that may unclog something before you have to tear the thing down.
Feb 12, 2011 | Pramac Commercial 5000 Watt Honda ...
Generator ran fine Friday evening but when I cranked it Saturday evening it ran from 10:00pm to around 2:00am then quit. I woke up to a cold camper. I was able to re crank the generator but it runs real...
If plug is fouled, that would explain running rought and some smoking. But for something to happen all of a sudden, I would suspect bad fuel, which can cause fouled plugs.
Dec 15, 2009 | Electrical Supplies
My yamaha yz 125 is dumping to much fuel and fouling out the plugs but i need to knoew how to adjust my carb its a 1997
There are only two adjustments to make on your carburetor; the idle speed, and the idle mixture adjustment. If the spark plug fouls frequently, first make sure you are using the correct spark plug. Your 1997 YZ125 uses an NGKB9EGV. Then be sure you are using the recommended two stroke oil, mixed to the proper ratio, in the fuel. Also make sure the air filter is not excessively soiled.
With all of the above confirmed and corrected, start the bike and run until the engine is up to normal temperature. Adjust the idle mixture screw to attain the fastest idle and best throttle response. Then adjust the idle speed.
If you are still fouling the spark plug, verify that the carburetor has the correct size jets by consulting your owner's manual. Keep in mind that if you are operating your bike at an altitude higher than about 6,000 feet above sea level, the stock jetting may be too rich. Down-size the main jet in small increments until satisfactory operation and the correct spark plug color is obtained.
Nov 02, 2009 | Yamaha YZ 125 Motorcycles
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Car spudered and die know it won't start
1 Inspect Battery Damaged or faulty battery and/or connections. 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. 3 Inspect Fuel Filter Clogged or dirty fuel filter 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. 11 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. 12 Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source. 13 Inspect Battery Cable Corroded, broken or poorly connected battery cable. 14 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. 15 Inspect Distributor Cap Loose or cracked distributor cap 16 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. 17 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. 18 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector. 19 Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit. 20 Inspect Spark Plug Fouled, damaged or broken spark plug(s). 21 Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s). 22 Inspect Timing Belt Slipped or broken timing belt. 23 Inspect Timing Set Slipped timing chain or worn timing gear(s). 24 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. 25 Inspect Ignition Timing Incorrectly adjusted engine timing.
Dec 08, 2008 | 1995 Buick Park Avenue
Electrical Supplies Logo
105 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
