Question about Electrical Supplies
Xg sf 2000 - Electrical Supplies
I've lost the manual that came with my tomahawk Sinewave 3000. Model Number XG-SF 3000ER Where can I get one. Thanks, Carolyn
try scribd.com. people post publications on this site and there is a lot of manuals available and it's free
Oct 24, 2009 | Cycling
My Sharp XG-E650UB does not power on or show power indication.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Aug 23, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Sharp XG-E650UB LCD Projector won't display picture.
it only takes up to a 640x480 resolution. it is a very antiquated projector.
Aug 10, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Aug 07, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
I have a Sharp LCD Projector, Model #XG-E650UB & it won't power up.
are there any leds lit? if not, it may be the bimetal circuit breaker. if the unit overheats, the breaker trips to cut the heat source, and needs to be reset manually. unfortunately, the top needs to be removed. it's located on top of the lamp housing (red button). if it's not tripped and still no power, you need to replace the power supply.
Jun 09, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
No Power or indication of power to Sharp XG-E650UB Projector
Have a nice day!
Jerry
Lampdeng Limited
Jan 28, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
SHARP XG-E1000UB
the model # you have given is for the bulb, not the projector......
Sep 12, 2007 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Gemini pmx 3501 and xg2000
Here you go: xg-2000: http://www.geminidj.com/disc._prod_manuals/AMPS/XG-2000/XG-2000.pdf PMX-3501: http://www.geminidj.com/disc._prod_manuals/MIXERS/PMX-3501/PMX-3501.pdf Hope this is what you want
Jul 29, 2007 | Gemini DUMRC01 Remote Control
Electrical Supplies Logo
49 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
