Question about Braun Watches
Add link to bn0095
The pins holding links are not screws how do i remove the pin then add link ?
  • 67 Answers
SOURCE: removing watch links
Look at both ends of the pin. One will look smooth, the other appears split.
You will need a suitable soft (wooden) support, and a very small dia. punch and a light hammer. The rest of the watch can be protected with a soft cloth.
You place the punch on the end of the pin which looks split, after arranging the watch so the link you are driving the pin from is supported on the edge of the timber. I drill a hole close to the edge of the timber over which I place the pin to be removed. Then by gently tapping the punch with the hammer, the pin should slide down into the hole.
One pin needs to be removed completely, the other can be left in the next link ready to tap back in after the link you wish out is removed.
The important thing is to have a decent punch! The diameter must be such as to fit easily through the pin holes, and the end should be flat. If you cannot make or find a suitable punch, one could be made from something like a darning needle.
Posted on Feb 22, 2008
SOURCE: Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Posted on Jul 14, 2008
slp11508
  • 43 Answers
SOURCE: Link pins keep falling out on Ceramic Watch
They probably forgot to put the little locking barrel back in before hammering the links shut again. Some watches have the link, the pin, and a barrel that goes in the link before the pin is hammered in. If your watch needs this barrel then the pin will NOT stay in without it, no matter what.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
slp11508
  • 43 Answers
SOURCE: Trying to remove links on a fossil watch w/arrrows pointing out
Are you pushing the links in the same direction as the arrow is pointing? If so, are you using a tool specifically made for removing watch links? If the answer to both of the above is "yes" then look closely at your watch. The pin will look different on both sides. One side will look like the head of a "screw" and the other will look rounded and just come to a point. You always want to use the watch link remover tool on the ROUNDED end and push the "screw" looking end out. It could be that your watch was assembled w/the pin facing the wrong direction.
If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
Posted on Jan 14, 2009
Removing links from a longines stainless bracelet. It's a L2.666.4.51.6 model and appears to have single screw pins but I cannot be for sure if they are actually screw pins or split push pins. Can...
here is a solution..
Each removable link on the watch bracelet has an arrow that indicates the direction of the pin to be pushed out .first decide how many will go out than find a tiny nail to be used as " pin pusher"
Simply align the pin that connects the links with the pin on the wood table and with a small hammer/plier hit it to push the pin out...there it comes..and after taking out linls ,connect the remaining link parts together and put the pin back into....
Some people prefers to use a pro type pin remover..it is a cheap tool..just in case pls visit the URL below..on this link there is an article as Watch Band Adjustment Tool Link Pin Remover too..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://reviewsalert.com/watch-repair-kit-16-pc-deluxe-tool-kit-repair-pin-remover/
Oct 07, 2011 | Watches
Tip
How to remove or add links to watch bracelets.
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done!
on Mar 07, 2010 | Watches
Tip
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
on Jan 06, 2010 | Watches
Need to remove links on band
Nov 22, 2010 | Fossil BQ9183 Wrist Watch
How do I remove links on a Movado elliptica?
Jan 08, 2010 | Movado Watches
How to remove watchband links from an Invicta watch
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Oct 20, 2009 | Lucien Piccard 26024 Wrist Watch
Adjusting a casio s940db watchband
  • On the inside of the band, locate the links with the arrow etched on them. The arrows mark the removable links.Lay the watch on its side on a flat surface with the arrows pointing downward. Be sure to leave about 1/2 cm of space between the bottom of each removable link and the flat surface. Using a 1/32" flat head jeweller's screw driver (or metric size 1.0), insert the tip of the screw driver into one side of the removable links' pin holes. You will find that the pins have an end that looks like a screw head. This is misleading - press down very firmly on the other end. Press downward firmly to make the pin pop out the other side. Be careful not to lose it.Remove the pin on the other side of the arrow-marked link.Repeat as necessary to remove half the needed links. You will remove the other half from the other side of the band to maintain equal band length.Flip the watch over so the arrows are pointing upward.Align the holes in the remaining links. Insert the rounded edge of one of the pins into the open link hole. The pin will go in without trouble until the top.Holding the pin in place, carefully flip the watch over again and firmly push the pin fully into placing using the flat surface. The pin will snap into place.Repeat for the other half of the band as necessary.
  • Sep 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Want to fit a watch band. take links out.
    You need a link tool. You can purchase this item on Ebay or watch parts sites. Some have a little track that you put the band on and screw a pin into the pin on the band and it pushes the split pin out and you remove the link. Pay attention to the pins on the band. You need to push out the side with the split pin that looks like a flathead screw. It sometimes is. In most cases it is a pin. When the link is removed you have to connect to the next link and push the pin into the hole again and it shoul go in the direction of the other pins. The pin should go in on the side with the split looking pins. You will need special tools: pin pusher device, a pin block and hammer with pins to hammer out the pins on the band usually. Some or most folks take classes to learn this but you may be handy and figure it out.
    Dec 03, 2008 | Invicta Watches
    Link removal
    here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at Info@Webjeweller.com 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: Info@WebJeweller.com Copyright © 1999-2006 webjeweller.com. All rights reserved.
    Aug 10, 2007 | Fossil AM3425 Wrist Watch
    Watches Logo
    43 people viewed this question
    Top Braun Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Braun Watch Expert? Answer questions, earn points and help others
