Sir i installed 2 os windows xp(shows earlier installed os) and windows 7 now i want to remove windows xp which had disc error while installing it and it does not start but win 7 works fine?
  • 41 Answers
It can be difficult to remove, your best trying to repair it with the same install disc first, or just forget it's there and you can manually delete the windows folders/files, removing can be tricky with dual boot unless you put it on a seperate drive then you can just format the drive it was on but backup your working OS first just in case, i had same issue and googled for long time and decided to leave it where it was in the end to avoid problems, there is a way to stop it showing up at boot up if your getting the option to boot from 2 OS but i forget how to remove this now, a quick google will show u.
Posted on Nov 23, 2013
SOURCE: Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Posted on Nov 11, 2008
  • 115 Answers
SOURCE: insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
Posted on May 14, 2009
  • 52 Answers
Hi Sue,
Your problem isn't Microsoft it's the manufacturers, they will specifically code drivers and the hardware configs especially for Vista because that's what they ship with. Unfortunately there isn't alot you can do apart from trying a XP Pro disc with service pack 3 on it. Give that a go and if that doesn't work it maybe worth speaking to Microsoft directly for further assistance.
Posted on May 22, 2009
SOURCE: how to compaq cq40-301tu install windows xp
You need to have SATA drivers, before installing Windows XP. SATA drivers are not included in the CD, unlike Vista. There are many websites which explain how to include SATA drivers in your CD. You may have to find right SATA drivers depending on your laptop.
Posted on Sep 06, 2009
Davethesnake
  • 689 Answers
SOURCE: I want to uninstall the Android feature (I have no
you might be able to configure your set up using "Fdisk" a utility that erases and partitionjs your hard drive.Do a search and get to know its workings.
Good Luck
Davey Snake
Posted on Jul 20, 2011
When i turn my xp on i get a fatal error 0x2. can this be fixed
Yup it sure can simply re-install your os if its a xp download tiny xp rev 10 from a bit torrent site. If the computer has vista or win 7 installed you will need to find a windows 7 disc after downloading it go back to the bit torrent site and download removewat it delets the windows activation technologies. To install a os put your boot disc in the cd drive press enter when promt delete all the old partitions(data) install the os on the blank hdd space it should take it from there! hope this helps.
May 11, 2011 | Computers & Internet
Dear sir/mam I want to install win xp in a win 7 installed laptop, (compaq 510) but there was some error to install it (blue screen error). Sir please help me to install win xp the same system with...
You cannot downgrade Windows 7 from Windows XP by not reformatting the hard drive. You need to Remove Windows 7 first, before installing Windows XP Operating System. In order to use the Windows XP CD to fully reformat the Hard drive, follow the steps on the link below.
http://www.windowsxpprofessional.windowsreinstall.com/indexinstallguides.htm
Apr 04, 2011 | Computers & Internet
Sir i have aspire 4738z p6100 with windows 7.can i use xp operating sys.
Yes you can use windows xp thereshall be no problems.
In order to use windows xp you have 2 options,
1. Install windows XP on your computer ( that will remove windows 7)
2. You can make it a dual boot where you can have both the operating systems. (win 7 amd win xp)
To install windows xp you will need a windows xp os disc with a valid license key with the help of the disc you can install windows xp.
Nov 03, 2010 | Acer Computers & Internet
I have a sony NS 230 with windows vista and want to instal windows XP so I cant do this case from both ways before moving Vista OS @ after that & in both cases I had microsoft blue page with 0000007B...
first remove all the additional hardware connected to the Computer.
2. install the Intel SATA Driver usign the USB floppy drive.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNS230E&upd_id=3748&os_id=7
3.Please read all information thoroughly before downloading and installing any files.
4. Try installing Windows XP SP 2 OS now.
5. If that does not work. restore the factory installed OS.
6. Restart the Computer, press F10 key at startup to aceess the Recovery Center.
7. Select Restore C Drive to restore the computer to factory settings.
8. If recovery partition is not accessible, then get the Recovery Discs for your Computer and restore.
Jun 22, 2010 | Sony VAIO vGN-NS235J/L Notebook PC
Hav to change my os
hi sir. its eay to install the xp. First format your pc and then boot it with xp cd if you have the XP cd. else you can download the windows XP from the following link:
http://www.softwarepatch.com/windows/windows-xp-service-pack-3.html
or
http://www.soft32.com/download_123572.html
all the best..
Feb 10, 2010 | Computers & Internet
How to format Satellite A200-24A
Sir,
Iam using toshiba Satellite A200-24A model laptop.already this laptop contain windows vista. i want to instal Windows 7.can you please help me how can i install Windows 7 and how can i download the 7 drivers.
Please Help me
and send me the result
kaihsanullah@hotmail.com
Jun 04, 2008 | Computers & Internet
Internet Explorer 7 beta version uninstalling problem
Go to ControlPanel > Add Remove programs scroll down and select the Internet Explorer 7 beta X, then click on chage remove. If you are not able to see the item see at the top of the window and "tick" show updates. It will display the IE installation. Tell me if it worked else you will have to manually uninstal it.
Nov 14, 2007 | Computers & Internet
Replacing windows XP
Dear ashwagosha If you replace or upgrade your os the nothing to worry to remove privious version do one thing:-right click on your my computer icon - properties- click on advance tab- go on startup and recovery-setting-select default operating system-edit-delete the old operating path file and save it. bye
Sep 26, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
