Question about D-Link Computers & Internet
Disconnecting dap 2360
My office wireless internet keep disconnecting in a few minute. T his is happened on my computer only My friends computer internet working same as me
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Your wireless network card in your computer is failing, or the cable to the computer is bad. Because you said wireless internet, I am going to assume that you are connected to the internet via wireless nic. If your pc hasn't been rebooted for a while you may want to try a reboot and see if that doesn't fix the issue.
However, if the problem remains you will likely need to get another wireless network card.
Posted on Nov 25, 2013
2 Suggested Answers
  • 11 Answers
SOURCE: My office wireless internet keep disconnecting in a few minute. This is happened on my computer only. Tried change my wireless channel, but the problem still there. My friends computer internet workin
well try makeing sure that there isn't any signal interferance if there is then do a via private network.
Posted on Jan 13, 2012
Multiple ssid and encryption problem
If you are protecting your SSID's with passwords every device that connects or tries to connect will have to know or have that password. Usually password protecting the SSID's is not needed if you don't broadcast them.
Dec 07, 2013 | D-Link Air Premier DAP-2360 Wireless...
Disconnecting in a few minutes
Change your position , that might help the signal to be better, wireless signal gets obstructed
Nov 23, 2013 | D-Link Dap-2310 Wireless Access Point
Disconnecting in afew minutes
Nov 23, 2013 | D-Link Air Premier DAP-2360 Wireless...
Disconnecting with dap 2360
Check your wireless network card on your computer.
if you can connect with a wire to the router, see if the problem persists.
Nov 23, 2013 | D-Link Computers & Internet
Can't configure the network with ethernet cable
Hey, you're almost there. The connection between the no-wireless PC over ethernet to the DAP-1360 Repeater is fine. The reason it can't connect to your LAN or the internet, however, is that the repeater isn't actually repeating your Ofir network, it is instead creating it's own, completely isolated wireless network (Ofir_EXT).
The D-Link setup and documentation is confusing, and doesn't have proper instructions for the repeater setup.
Rerun the setup wizard, setup as a repeater, then select manual configuration method.
Now, enter the wireless network name of your the network you want to extend (in this case, Ofir). Then enter the same security and password etc. for Ofir in the following fields, just like you were connecting to Ofir from a smartphone or laptop.
Once that is finished, you should be up and running. If things worked, you should NOT see any new wireless network. There should be Ofir and just Ofir. Wireless repeaters work invisibly, you'll still connect to the same network like you always did, but now it will have much improved range thanks to the DAP-1360. The computer entherneted to it should be networked on the wireless LAN and have internet access after this as well.
Good luck, I hope my instructions were clear. Wifi networking is easy, it's understanding all the manufacturers less-than-intuitive software that makes it hard.
Oct 16, 2012 | D-LINK SYSTEMS DAP-1360 Wireless N Range...
Why does my Belkin N wireless router disconnect and reconnects
Turn off the firewall in the Router
Step 1 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 2 :On the left side click Firewall
Step 3 : Leave the password blank and click submit
Step 4 : Disable it and click Apply
Step 5 : Restart te Router And try a Skype call
Step 6 : If it works let me know at warrierrakesh@ymail.com
Jan 04, 2010 | Belkin Wireless-N Wireless Router with...
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Im trying to install a DAP-1522 as a bridge with my Linksys WRT610N V2. How do you do it. I find DLINK very hard to set up
Hi Friend,
Please follow the steps to install the DAP-1522
1) First connect your computer to the linksys router with a wire,dont connect the DAP. Now if u have windows XP please try this
2) Now ,click the start menu>run>type cmd and hit enter
3) In the black window,where the cursor is blinking type ipconfig/all and hit enter
4) Out of the bunch of information please note down the ip address and the default gateway
5) if the default gateway is 192.168.1.1
6) disconnect the computer from the computer and connect the DAP to the computer directly
7) click start menu>control panel>to your left you will see "switch to classic view",please click that>double click the icon named network connections
8) Inside network connection you will see an icon named Local Area Network connection,right click and click properties
9) under the general tab you will see Internet protocol(TCP/IP),select that and click properties
10) In the new message bos you will see 4 radio buttons,select the second one from the top
11) in the Ip address box type 192.168.0.1
12) Click ok and then close
13) now open the internet explorer page and delete evrything from the address bar and type the number 192.168.0.50
14) You will get the page of your DAP
15) set the fixed ip of the 1522 to 192.168.1.50,DHCP should be disabled.
16) Make sure that you have set the wireless password so that no other people can mess up with your network
170Save the settings.Once done unplug the bridge and enjoy working wireless.
Warm regards
Chiranjeet Mitra
3)
Oct 08, 2009 | Computers & Internet
Computers & Internet Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
