Question about DreamCatcher Interactive Legend of the Prophet and the Assassin for Windows
Installing : error copying to temp directory vcl40.bpl
I have been having problems installing this game. When I double click on the Setup program. I get an error message box :- error copying to temp directory : sourceC:\Legend\vcl40.bpl dest:C\Windows\\TEMP\vcl40.bpl I have even tried clicking on Autorun also, same problem. Tried even on Compatibility on win xp mode still no luck. Please help. My Machine Specs Laptop : Acer Aspire 4741G Windows : 7 Home Premium 64Bit HDD : 500 GB CPU : Intel Core i5 M450 2.40Ghz
2 Suggested Answers
SOURCE: Problems with the Start of the Game Atlantis 1
Ok, thank you very much. I solved because I found out that my cds vwere damaged. I will find new good ones.
Posted on Mar 07, 2009
Error When Installing Legend of the Prophet & Assasin
It looks to me like the Destination folder location has a typo(or 2), see after where it says \Windows\\ there should be only one \ so if your installing via steam or other similar installer check in the setting for the FOLDERS and check destination folder when you see the path try removing the \ at the start.
Alternatively manually go to the folder C:/Legend/
copy the file vcl40.bpl to C:/Windows/Temp/
You may find their are more files u need to do this with but should flag them up as u go, but hopefully you can just correct the destination path error. Hope this fixes it.
Nov 23, 2013 | DreamCatcher Interactive Legend of the...
I just installed rocky mountain trophy hunter versions 2 and 3 on my computer and am having problems with both. My computer is saying that RMTH 2 is not a valid win32 application and i cant install RMTH 3...
For RMTH2, make sure you have the 1.1 patch and try again. If it is still failing, copy Rmth2.exe directly from the install CD into the folder that has the same filename and overwrite the installed one.
For your RMTH3 issue, it is usually caused by older software not being able to find the temp directory. Try copying the setup files to somewhere like c:\temp and install from there or set your temp variable to c:\windows\temp instead of your profile temp folder.
Apr 19, 2017 | Rocky Mountain Trophy Hunter 3 for Windows
Softwear Instalion
what problem are your experiencing?and what software are you trying to install?Please specify the problem and software so we can give you the solution//
Jun 27, 2011 | Computers & Internet
Do not know how to install software
How to install a software program can depend on the operating system being used and the program being installed. Because of all the different possibilities, we have created the below steps as guidelines for installing programs in each of the major operating systems.
Notice: This document has been created as a basic overview on how to install software programs, games, and utilities on your computer. If errors are encountered during the installation, this document will not cover those errors.
General Tips
Microsoft Windows 95, 98, NT, ME, 2000, and XP users
MS-DOS Users
General Tips
  • Make sure your computer meets the requirements of the program, game, or utility you are attempting to install.
  • The manuals for the program or the readme file located in the same directory as the install commonly contain exact instructions on how to install a program.
  • After installing or during the installation, a program may need to install other programs, files, or utilities before it is able to run. If this is the case, the program will commonly prompt you to install the program or you may need to run a separate install before the program can be fully used.
  • When installing a program, utility, or game, it is always a good idea first to close or disable any other programs that are running.
  • After installing a new program if it prompts you to reboot the computer, do it.
Microsoft Windows 95, 98, NT, ME, 2000, and XP users Many software programs, games, and utilities have an AutoPlay feature that will automatically start the setup screen for the software program when the CD is placed in the computer. If your program, game, or utility contains this feature, run the installation through the screen that appears after inserting the disc.
If you are installing a program, game, or utility that does not contain this feature or you are installing a program from a floppy diskette, follow the below steps.
  1. Open My Computer.
  2. Within the My Computer window, open the drive that contains the installation files. For example, if the files are on a floppy diskette, open the A: drive. If they're on a CD or DVD open the D: drive or the letter of the disc drive.
  3. Within the drive that contains your files, locate either a setup or install file. Double-clicking on this file should start the installation for the program, game, or utility. If you see multiple setups or install files, try to locate the Application file or double-click each of setup or install files until you find the file that starts the installation. Many times the icons associated with the installation files have the same name.
An alternate method of starting the installation in Microsoft Windows
  1. Click Start and Run.
  2. In the Run Window, type x:\setup or x:\install where x is the letter of the drive you wish to start the installation from. For example, if you are attempting to install a program from the floppy disk drive you would type a:\setup or a:\install.
MS-DOS Users Users installing a program from Microsoft DOS should have a basic understanding of the MS-DOS commands. If you are unfamiliar with any of the commands listed below, click the link to get additional information and examples on the commands.
  1. Before installing a program in MS-DOS, you must switch to the drive and/or directory that contains the installation files. If you are installing a program from a CD or diskette, switch to that drive. Additional information about switching drives in Microsoft DOS can be found on document CH000515. If the installation files are located in a different directory, use the dir command to list the directories and the cd command to switch into the appropriate directory.
  2. Once you are in the directory or drive that contains the installation files, run the executable for the setup. Many times this can be done by typing setup or install at the prompt to start the installation. If both of these commands give a bad command or file name error message, type dir *.exe or dir *.com or dir *.bat. These commands will list any executable files; if any files are listed, attempt to execute these files to run the installation or setup of the program. If no files are listed when typing all three of the above commands, it is possible that either you are in the incorrect directory or drive letter, or that the program.
Additional information about running an file from MS-DOS can also be found on document CH000598.
Additional information:
  • Information about problems that can occur after an install can be found on document CH000123.
  • See document CH000506 for information about how to extract a file that you've downloaded before installing a program.
< Please Rate :) >
Apr 12, 2009 | Computers & Internet
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
Let's Ride Corral Club will not run
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Nov 11, 2008 | ValuSoft Let's Ride: Corral Club for...
Installing
The game was released back in 2002, that means it was designed for older versions of Windows OS (Windows 98/ME/XP). The updates for the game do not have any patches for the installation to be compatible to the new Windows Vista OS as they were released on November, 21st 2002 aslo that patches resolve functionality issues after the game is successfully installed.
Oct 12, 2008 | ValuSoft Hard Truck: 18 Wheels of Steel...
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
The contents of this file cannot be unpacked.The executable you are attempting to run has been corrupted.
When I try to install the software, I get an error message. The installation just quits. trnsp.gif Answer An installation error is defined as any issue or error that prevents the Setup program from fully completing the task. Installation errors can manifest themselves in several different ways. One common installation problem is the Setup program is interrupted with a message indicating some type of problem. Another type of installation error is when the Setup program simply disappears or doesn't complete for any reason. When Setup is interrupted with an error
Many installation issues will be accompanied with an error code and then an error message that identifies the problem. Because the camera software uses the Windows Installer, the exact definition of the problem can be obtained by looking up the error code on Microsoft's website. Two common errors are Error 1904 and Error 2711.
When Setup simply disappears or doesn't complete
Note: When installing software, administrative rights are needed to install all the files for camera software. If you are logged in as another user without administrative rights, the software may not install/function correctly.
First try booting clean. If you are using Windows XP, Windows Me, or Windows 98, click here for instructions on booting clean. If you are using Windows 2000, click here for instructions on booting clean. Once you have booted clean, then try to install the camera software.
Since booting Windows clean may disable CD-ROM support, we recommend you download the latest camera software for your camera and use the download file to install after you have booted clean.
All other installation issues
If you are unable to find a solution to the installation issue given the above information, please try the following suggestions. After each suggestion, try running the installation program again.
  1. Reinstall the Windows Installer. This Windows Installer engine can be downloaded from http://www.microsoft.com/downloads/release.asp?ReleaseID=17343
  2. Windows 2000 Only. Stop the Windows Installer service and reboot the machine. To do this:
    1. Right-click on My Computer
    2. Choose Manage
    3. Click on the plus (+) sign next to Services and Applications
    4. Click on Services
    5. On the right side on the pane, double-click on Window Installer
    6. Choose STOP
    7. Reboot the computer.
If the service was already stopped, try starting the service, then stopping the service and rebooting.
If following through on the specific instructions above do not resolve the issue, please try the following standard diagnostics:
  1. Try a different installation media. For example, if you are attempting to install the camera software via the CD, download and install the latest web release. If you are trying to install the web release, try the camera software CD. Please note, the latest software can be downloaded here.
  2. Run ScanDisk and Disk Defragmenter. Both of these utilities can be found in the Accessories program group of the Windows Start Menu.
  3. Search for and delete all TMP or CHK files.
    For Windows 98 and Windows Me Users:
    1. Click on "Start", "Find" and choose "Files or Folders".
    2. In the Named field, type *.TMP and click "Find Now"; delete all files found.
    3. Repeat this procedure with *.CHK.
    For Windows 2000 Users:
    1. Click "Start", "Search" and choose "For files or folders".
    2. In the Search field, type *.TMP and click "Search Now"; delete all files found.
    For Windows XP Users:
    1. Click "Start", "Search".
    2. In the "All or part of the file name" field, type *.TMP and click "Search;" delete all files found.
  4. Empty the TEMP directory; this folder may contain files that are interfering with the installation. To do this, use the following steps:
    1. Right-click on My Computer and choose Explore.
    2. Click on the plus (+) sign next to the C drive.
    3. Click on the plus (+) sign next to the Windows directory. (For Windows 2000, it is the WINNT directory.)
    4. Click on the plus (+) sign next to the Temp directory. The right side of Explorer will display the contents. Select all the files listed in the Temp folder and delete them.
  5. Reboot the system and try installing the software again.
Jan 21, 2008 | Logitech QuickCam Express Web Camera
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Dec 27, 2007 | Logitech QuickCam Express Web Camera
DreamCatcher Interactive Legend of the Prophet and the Assassin for Windows Logo
172 people viewed this question
Top DreamCatcher Interactive Video Game Consoles & Games Experts
ray gallant
James Wishart
Are you a DreamCatcher Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
