Sumsung la32b450c4 tv the trouble is good reception and good sound but no raster or black picture.i checked the power supply section the voltage requirements is ok and i found out that there's no h.v. output coming from the inverter section.how can i fix that.thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Go to samsung and download the latest firmware for your tv apply it and problem solved
Posted on Nov 23, 2013
techman
  • 3130 Answers
SOURCE: TV LCD THomson 26"
If what your saying is that there are vertical stripes down the screen, You have a screen drive problem my friend. This could mean you will need to change the entire main board, the screen driver board if it is separate on this set, or the main LCD panel itself. These boards do not have any parts available for them and must be replace as a whole unit. Good Luck
Posted on Mar 20, 2007
  • 15 Answers
SOURCE: Sharp LC-15AV4U 15 in. LCD Television
Sounds like a lamp error.... either a defective or broken lamp within the LCD1.gif panel itself, or you have a bad inverter.
Posted on Apr 02, 2008
  • 191 Answers
SOURCE: Polaroid " 3211 TLXB red light no power
hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
Posted on Oct 12, 2008
budmrtn
  • 11361 Answers
SOURCE: INSIGNIA 26" LCD TV > > MODEL# NS-LCD26F
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 25, 2010
  • 11800 Answers
SOURCE: My TV has a 17pw26-1
No, the voltages are just fine. The fault must be either in the PMW itself or in the HT transformer - and the only way to fix that is to replace the entire inverter board.
Posted on Oct 19, 2010
Power light is on but no picture
you did not mentioned if you have raster or none, if your tv has raster but no picture your problem is in your I.F. section and your tuner, now if no raster, you can check your power supply, check your 5volts, 9volts, and 12volts check any alternatives that cause of no picture..
Sep 09, 2013 | Toshiba 40RV525U 40 in. LCD TV
Signal Problem
When the sound is working and the picture is not it indicates the main power supplies are working but the picture supply is not. The picture supply that powers the projection tubes is a high voltage generator and is very expensive to repair. Not even most tv techs now how to troubleshoot them. So, I cannot recommend you repair it yourself unless you are a trained high voltage tech.
The cost of repair - my wild guess - would be around $300. However, the real cost can only be determined by someone who can make an accurate diagnosis - which will require a hands-on approach the problem.
If you have any other problem please ask me..
Goodluck,
Please don't forget to rate me as fixya..
Feb 09, 2008 | Televison & Video
Jvc tv model av dx25,power on but no raster and sound
if you want to do it with your own, you will need a proper trouble shooting. which need the right device and tools to do the job and make sure you have at least a basic knowledge in electronic repair. the first place to be check will be the power supply section, you need to have voltage checking weather their is a secondary dc voltage from the power supply section going to the horizontal section. to turn on the other circuit and the flyback transformer. you have to know if their is a 135dc voltage at the power supply section,check at the primary capacitor using a digital tester.
Nov 28, 2012 | JVC Televison & Video
Sony projection tv 48inch year model 1997. we have only sound no picture.?
Your have problem in the power supply, since there is sound meaning the other section were working. Your Raster is missing or the horizontal and the vertical or your dont have high voltage to run the tube screen. Either the problem would be open Fuse or open resistor on the power supply or the Horizontal output stage damage.
Aug 15, 2011 | Televison & Video
Hitachi projection tv has no picture but has sound
hi.. if your projection TV has no raster at all, it has problem with high voltage supply. there are two separate power supply inside your TV for audio and for the high voltage for 3 CRT tubes.its very dangerous to service it by yourself.
Aug 14, 2011 | Hitachi 57F500 57" Rear Projection...
It looks like our Samsung LA32B450C4 needs hopefully only a new fuse. It's not readable anymore, so I don't want to buy the wrong fuse. No power but plugged in!
Can buy fuses it at any Radio Shack stores.The fuse it at the end of the power supply board.That the board,where the power a/c cord plug into it.Modern electronic equipments have very small chances the fuses dies in the normal operating situation of the devices.Tv have the power supply board problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 28, 2011 | Samsung LE32A457 32 in. LCD TV
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Panasonic COLOR CT-27G14A
check Vertical IC out (LA78..) and resistor voltage supply from flyback transformer to this ic. Check the STR main power supply(and resistor near, change value), some times seems good out main board,but in operation not good
May 18, 2008 | Televison & Video
Sound problem
  1. no picture &no sound raster ok.
  1. your problem is in tuner to vif section.
  2. check supply to TUNER & VIF section .
  3. check loose contact in above section.
  4. check components in VIF section.
  5. for ckt open the web site & download it fron there as given here.
  6. hope this will help.
  7. good luck.
http://www.eserviceinfo.com/index.php?what=search2
Oct 11, 2007 | Televison & Video
Picture does not bleed to edge
this symptom is caused by a poor regulation in the power supply circuit. too low dc supply voltage will result to insufficient deflection, both vertically and horizontally. black borders appear around the raster. receivers generally use regulator in the main power supply to set the dc supply voltage at the value that will allow the picture to fill the screen with a little overscan. defective regulator can result in a small raster. most modern receivers today are using ic (integrated cirduit) regulator. but if you are not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Feb 27, 2007 | Toshiba 27A43 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
