Question about Canon PowerShot S2 IS Digital Camera
Dead Camera For no apparant reason, not droped or wet, the camera would not turn on. I need a wiring diagram of the power on circuit so I can trouble shoot. Does anybody know where to find this on the net. I have changed batteries, removed and inserted memory card and moved anything that wiggles many times. Thanks Carl
  • 1 more comment
  • Anonymous Nov 05, 2007
    My wife was taking some pics with our s2is when it suddenly died. She thought the batteries were dead, but new batteries didn't fix it. There is absolutely no power. It is not the e18 problem even though the lens is extended, for the screen won't even come on. The LED light will not light up when we try to power it on. I have replaced the batteries, put in the original 16mb sd card, wiggled everything I can, etc. It appears not to be the ccd problem either, since the people with that problem apparently have power. Any ideas?
  • thanthan Nov 05, 2007
    Same as above. For no apparent reason, in the middle of shooting, it suddenly died. No e18, no simple blank screen like the ccd problem. There was simply no power. Fresh batteries did not fix it.
  • Anonymous Dec 04, 2007
    I have the same problem. My camera all-of-a-sudden died. I changed the batteries 3 times thinking that was the problem, but it's not. I love this camera and really don't want to replace it so please tell me what I can do.
Posted on Oct 25, 2007
My camera got wet and refues to come on
I'm sorry to bring you bad news, but that problem is probably terminal. In general with electronics, the components and wiring are waterproof, and if you get them to be totally dry before applying power, they'll be OK. The problem with cameras is that they're permanently powered by the battery (even if it's apparently off). While the electronics are wet, and powered, the printed tracks and components are eroded by electrolytic action.
Your only hope is to remove the battery immediately, dry the camera out (use a vacuum cleaner that won't mind a few drops of water to hurry the process along) and try turning it on. Sorry again for the bad news.
Feb 03, 2011 | Kodak Easyshare C190 12MP Digital Camera...
THe camera can't always find it's memory card even though it is in there. After turning it off & on again a few times, it does, but then the camera is also randomly turning itself off for no apparent...
OK, to be honest, i will always rather try to fix, than to replace. But, in this case it sounds like an internal circuit error. The repair cost for this problem will basically cost you the same as a new camera.
So, at this point i would rather suggest you to buy yourself a new camera.
Kind regards
Nov 21, 2010 | Canon PowerShot SD1100 IS Digital Camera
I droped my camera now when I turn it on is
Apparently, your camera has some form of anti-shake control which is now not functioning. Anti-shake helps hold your camera steady even if you move slightly.
Jun 29, 2010 | Casio Exilim EX-V7 Digital Camera
My camcrder got droped in the pool ,it will not power up
How wet? got rained on? or been in the North Sea for 10 years? if slightly wet by now you ought to have removed the Battery from cam, opened all hatches removed all media (if you can) stand in warm room (no camera not you) for about 6 days, then connect power and kneel.
Jun 20, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Flash doesn't work (ever). got it wet
Water on or in any kind of camera can spell doom to the inner workings and circuits.
If the camera ever gets any kind of water inside, the chances of fixing the camera is not good.
Something which could be tried when any kind of water gets into a camers's insides is this:
Immediately remove the battery or batteries. The reason for this is that the circuits are live when a battery or batteries are installed. This can lead to damage and shortages which will lead to all kinds of circuit troubles.
My suggestion is to sell the camera on a site such as Ebay for parts, as is, or repair parts.
The reason is the the repairs more than likely will cost more than you want to spend.
Aug 31, 2009 | Olympus FE-190 Digital Camera
Hi there, I purchased a Casio Exilim Ex-S880 8.1Megapixel Digital Camera last Christmas. Intermittently the camera just stops working for no apparent reason. The power just turns off with the lens in the...
I'm using a 2Gb card which currently contains about 600 photos.It appears that the camera is having trouble with this quantity. Removing half the photos solved the problem.
May 09, 2008 | Cameras
Nothing apparently wrong; acts like battery's dead
Here are some simple things to try first for a camera that won't power on:
Nov 24, 2007 | Canon PowerShot S60 Digital Camera
Canon Ixus 40 corrosion
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
Nov 22, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Dead Canon A75
A complete camera failure is usually caused by a power problem. Naturally, after checking the batteries, you should inspect the metal battery terminals inside the battery compartment. Also, many cameras (including the Canon A-series) have a memory card door with a safety interlock lever (power switch) that is engaged only when the door is completely closed. Finally, I have learned (from a Canon camera forum at Digital Camera Resource) that there is a small fuse soldered to an internal circuit board that sometimes fails for no apparent reason with several different "A" series Canon digital cameras. The fuse story, with photos for those brave enough to void their warranty and open up the camera, begins inside this thread, "Canon powershot A85 spare part needed!!!" at this web link: You'll need to read a couple pages down to get the entire story. Good luck.
Jun 08, 2006 | Canon PowerShot A75 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
101 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
