Question about Meade ETX-70 (240 x 70mm) Telescope
Ext-70 slewing motor turns
I went to train the drive on a Meade EXT 125 the slew moved extreamly slow to the right and would not allow to center to the left on the next step. Now I can't slew to the right it sounds like the gears...
I have a YouTube video about this just search for Telescopeman on YouTube. However if you cannot move the scope up-down-left or right with the controls either the hand controller is defective or something is broken inside the scope. Possibly a worm gear is not engaging or is simply broken.
https://www.youtube.com/watch?v=iv9BCpcF5mc
Feb 14, 2015 | Meade ETX-125AT (500 x 138mm) Telescope
My ex 30 digger is not turning right what could be wrong
Either slew motor or a shuttle valve
Dec 28, 2014 | Garden
Kobelco sr135 excavator won't slew right or left.
You have an hydraulic problem in most likeyhood. Check the fluid level, check the lines. I don't know exactly what a Kobelco is, but anytime a contractors piece of machinery won't slew right or left it has been a hydraulic fluid problem.
May 10, 2014 | Liebherr Excavator
Lost the slew on a kamatsu pc40
Check that the key in the drive gear is not sheared in half. check that by trying to slew and see if the drive motor is working. The hydraulic motor may be seized up
Mar 19, 2013 | Joal 1/32 Komatsu PC 450 LC-6 Excavator
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
First time using the mead etx 60at. I turned it on and set the date / time / enter. Then set it at north and horizontal,enter. It asked if i wanted the easy alignment, I said yes. I said searching. Then it...
Did you lock down BOTH clutches?
You should have Calibrated motors and trained drives before you actually tried to do a goto.
Read this manual completely:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-60-70AT%20manual.pdf
Aug 21, 2010 | Meade ETX-70 (240 x 70mm) Telescope
The plastic part in my bow mount Turbo 765MX(36lb.thrust) Minkota
Hello poorjohn, stroll to www.minnkotamotors.com/index.asp When you call ask for ext #406 and ask for Dave. Refer to my logon 'themoneypitt' He is a great guy. Merry Christmas.
Nov 21, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Slew problem
You did tighten the DEC knob? If you did the altitude gears (a worm gear) is not engaing properly. You can either return it to Meade for repairs or attempt them yourself.
I would also check that you have fresh batteries and that the UP button on the hand controller is not broken.
Dec 28, 2007 | Meade ETX-70 (240 x 70mm) Telescope
Meade ETX-70 (240 x 70mm) Telescope Logo
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Eric Hidle
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
