Question about Samsung ES90 Digital Camera - Silver"
How can i reset the device?
My camera do not display options in shooting menu of settings and i cannot reset it either.
I cannot use my camera properly
Complete reset is not possible. The language and date and time stay as they are. But you can set back shooting options. For that press the menu button and goto the second logo from the top, the camera/ Shooting Menu: Shooting Options.
The first line of the menu is Reset shooting menu.
Press there and follow the options.
Then you can reset the custom settings.
Third logo on the left in the menu. The pencil and called Custom Settings. Press that and chose line 1 again.
Jan 19, 2014 | Cameras
How to reset samsung ES95 lcd colors
Press menu when in shooting or playback mode.
Goto settings.
goto reset and press yes
This will reset the menu's and shooting options.
It will nit affect date, time and language settings.
This you can find in the user manual on page 95 e.v.
http://downloadcenter.samsung.com/content/UM/201302/20130207154253245/ES95_English.pdf
Oct 21, 2013 | Nikon D40x Digital Camera
Nikon 1 j1 will not start
sir,
power on, press menu, scroll to setting option, reset set up then go to shooting option push reset, all the system will be set to default.
May 28, 2012 | Nikon 1 J1 Digital Camera
How do I set camera to shoot on continuous?
Press the shooting mode button in shooting mode to display the shooting-mode
selection menu and set the shooting menu to Continuous.
Note:The maximum frame rate with continuous shooting may vary, depending upon the current image mode setting and the memory card used.
Mar 24, 2011 | Nikon COOLPIX L18 Digital Camera
How do i change picture size on my coolpix l18
Press the shooting mode button in shooting mode to display the shooting mode selection menu and set the shooting mode to Auto (the green camera). Press MENU to display the shooting menu. Navigate to "Image Mode" if necessary and press OK. Take your pick of sizes here, then press OK to save the change and then MENU to exit the menu.
Nov 12, 2010 | Nikon COOLPIX L18 Digital Camera
How do I change resolution on my nikon l18
Press the shooting mode button in shooting mode to display the shooting mode menu and set the shooting menu to Auto mode (the green camera). Press MENU to display the shooting menu. Use the arrows to select "Image mode."
Aug 04, 2010 | Nikon COOLPIX L18 Digital Camera
Captured photos have horizontal lines on them but doesnt appear while capturing
A multicolor horizontal line may display on the camera LCD screen if there is glare on the subject being photographed. Avoid photographing very shiny surfaces that reflect excessive amount of light into the camera lens.
Follow each step below until the issue is resolved:
  1. Change the position of the camera by shooting at a different angle.
  2. Shoot in an environment with different lighting.
  3. Adjust the zoom level.
  4. If the issue still occurs, try resetting the Camera back to factory settings.
To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK)
If the issue persists, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. Please make sure that you turn ON the Camera before you reset it.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Jul 26, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Nov 21, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Shooting features
There is an option where you can set the camera to capture two images side by side, within the same frame. This feature is called “2 in 1” and can be accessed through the Mode Menu. Press the OK/Menu button, and use the right (>) arrow key to access the Mode Menu. Press the up (^) or down (v) arrow key to navigate to the CAMERA tab and then use the right (>) arrow key to access this sub-menu. Use the down (v) arrow key to navigate to the “2 in 1” feature and by using the right (>) arrow hey the “2 in 1” feature will be active for the next two shots. After the second shot the camera will display the menu option for “2 in 1”. You can select the option again, or you can return to normal shooting by pressing the OK/Menu button.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Shooting features
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Samsung ES90 Digital Camera - Silver" Logo
41 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
