Question about Watches
Mambo Watch Analog - Watches
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
My DZ 7241 watch analog watch does not turn on?
please ckeck the crown of your analog time if it is pressed down, if it is pressed it is possible that even if it is a brand new watch, the battery has no power at all.. it is maybe that your newly purchased watch is been in its selling showcase fo a long time, so that the watch movement consume all the power of the analog's battery.. you have to replace the battery of your analog., Note: your watch has three batteries. I hope this will help..
Feb 05, 2013 | Diesel DZ7241 Mens Watch Stainless Steel...
I am not sure if my new watch is an invictor but it is the type with the locking band.I need to tighten it but don't know how to go about it Thanks Peter
It depends on how much you need to tighten.
There are pins in the clasp that can be moved also the links themself can be removed.
Probably best goto to a jewellers and they should be able to do this instantly and will have the tools needed.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | Invicta Mambo Slim 9876 Wrist Watch
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 | Watches
Digital/analog watch... analog part doesn't run
A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
Oct 17, 2009 | Watches
Watches Logo
27 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
